Home > Puma (Tdci) > Wiper Motor
kkma1560
United Kingdom 2012 Defender 110 Puma 2.2 USW Keswick Green
Wiper Motor
So one of the wiper wheel boxes seized in my 2012 tdci 110.
As such a faff getting dash removed, I thought I would replace everything. So new motor, new wheel houses, new cable etc.
Have put back together and the new wiper motor is making an odd noise when on slow speed or intermittent.
I have put new and more grease in the wheel houses, cable and in motor.
Any other ideas what it might be?
Thanks
[img]https://www.defender2.net/gallery/albums/userpics/32694/Video.mov[/img]
Post #1056917 10th Jan 2025 3:51pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
I've listened a couple of times. It seems to me that some thing is tight. Did the cable go in free and easy? I would pull the motor, remove the cable and drive cog and check to see if the armature freeplay adjustor is too tight.
Post #1057078 11th Jan 2025 7:50pm
jst
Too tight on worm gear drive? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057085 11th Jan 2025 8:10pm
kkma1560
You're both right. Took motor apart and filled with even more grease, same with drive cable, and now sounds normal.
Thanks for both your help, much appreciated.
Post #1057113 12th Jan 2025 9:46am
