![]() | Home > Maintenance & Modifications > Soft top conversion |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2503 ![]() ![]() |
theres no interior lights on a soft top, you'd have to fabricate a mount onto top of screen if u still want one
the sunvisors do bolt to top of screen 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8364 ![]() ![]() ![]() |
I am looking for a roof, side panels and rear door I your selling. Cheers
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
I bought this bracket from Protection & Performance, takes the standard light (which I fitted LED's to).
This photo dates from 2013 but I presume the bracket is still available as it was a top piece of kit. ![]() Click image to enlarge ONE LIFE, GET IT! |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1776 ![]() ![]() |
my interior light solutions.
![]() Click image to enlarge ![]() Click image to enlarge |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Very neat solution. Where is that mirror from? WARNING.
This post may contain sarcasm. |
Mirror is from an MGF
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 547 ![]() ![]() ![]() |
Very nice, would you have a part number. was it hard to fit
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 76 ![]() ![]() ![]() |
Conversion was delayed, but has started in anger now. Today saw the roll hoops being test fitted.
![]() Click image to enlarge Thanks for the interior light info, very usefull. ![]() Click image to enlarge Anyone got a photo of the softtop windscreen top bar, without the hood fited? Trying to work out how it attaches. TIA 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
it will only go one way with the bead for the hood along the front. have you offered it up? Cheers
Bit more research and it looks like I have a bolt-down rail, rather than one with lever/hinges. So will need a socket to remove the hood when required.
https://awttrimcentre.co.uk/shop/landrover...frame-set/ Might order the one with the levers, just so it's a bit easier. 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
I've emailed P&P to see if they still make this bracket, looks like the perfect solution. 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
Found one of these on eBay. Just need to figure out how to mount ![]() 2024 90 D300 HSE X-Dyn HT - Santorini Black |
Well, this is almost done now. Electrics to sort and I'm installing a TransK9 drawer in the back.
![]() Click image to enlarge Swapped from 315 MT's to 285 AT's and still think it looks great. ![]() Click image to enlarge Guys that have done the work have been brilliant, as anyone knows, nothing goes to plan or is straight forward on a Defender! https://alteredimagecoachworks.co.uk/ 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
Just an update. Installed the TransK9 drawer and fitted a marine ply deck over the top. Then had a "boat deck" finish made to go on top. Company that did it is called SurfDek, really looks the business and loads cheaper than a real teak deck.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cargo rails from MUD work well. Excuse the faded seat covers, fitted for the trip to Morocco in a few weeks time. 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
