Home > Maintenance & Modifications > New Topic Name: Trailing Arms bush removal DONE!!!!!
Page 3 of 4 <1234>
Mo Murphy
Superpro.
50 Shades of Pennine Grey
Post #1056746 9th Jan 2025 10:09am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I have recently replaced mine using the same methods as you,though I find a recipricating saw easier than a hack saw.I have never had to resort to heat though.
I replaced mine with Super Pro poly bushes,which I got from Gwynn Lewis.Very good quality product,even beter than Polybush IMO.
Marc.
Post #1056747 9th Jan 2025 10:13am
Grenadier
Thanks both.
Unfortunately I need them this weekend. Can't find Superpro in France. I have a choice of Britpart, Terrafirma or what I've already got, which aren't even original LR, just 'AllMakes', so could therefore just be Britpart.
Later this year I plan to do a full underbody upgrade, with GL and Ashcroft parts, so would do a full super pro kit then. In the meantime, 25€ for the Terrafirma, arrive by tomorrow, or stick with what I've got? I know TF don't have a stellar reputation, but I'm thinking of ease of fitment and use for just 6-8mths.
Watchoofink? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1056749 9th Jan 2025 10:26am
excossack
If you are planning on replacing them all later in the year, go Terrafirma to get you mobile.
In the meantime, maybe keep eyes peeled for a spare set of arms and then you can swap bushes at your leisure. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1056751 9th Jan 2025 10:36am
Grenadier
Makes sense Thumbs Up Monsieur Le Grenadier
Post #1056754 9th Jan 2025 11:15am
rustandoil
Nice one! You can put the cash you've saved removing the old bushes yourself towards a Super Pro upgrade.... 👍🏼
Post #1056757 9th Jan 2025 11:32am
Should you decide to fit the old "metalastic" (original) style, lubricate the hole in the arm and the outside of the bush with a good copper grease before pressing them in. You will find that they then come out relatively easily in the future.
If you are going down the polyurethane route, ignore this advice!
Post #1056759 9th Jan 2025 11:53am
Grenadier
Well, assuming a garage with a lift, impact drills, a vice and a couple of guys who know what they were doing could likely get it all swapped in a morning (3hrs?), at the local rate of 100€/hr, I won’t be so much putting the savings ‘towards’ the GL Superpro kit, as buying it outright. Assuming it doesn’t get spent on beer first…. Whistle
Overall, it’s been a standard Defender DIY maintenance experience: Worth doing, took longer than expected, was at times bloody frustrating, shed blood, but ultimately a rewarding experience. I’m saying all this without having yet attempted to put everything back together mind you, bushes should arrive tomorrow, so a job for Sat am, so fingers crossed my positive ‘chi’ doesn’t change by lunchtime…. Thumbs Up Monsieur Le Grenadier
Post #1056760 9th Jan 2025 11:55am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I’ve had a chassis set of britpart black poly bushes since I rebuilt the truck. It’s done about 20k since and they’re all good, but given the choice I’d probably get the ones Gwyn Lewis supplies next time. Glad the burn and saw method worked - that’s what I always do- but a press would be nice! 1983 110 automatic OM606
Post #1056761 9th Jan 2025 11:57am
Grenadier
Going PU. Interestingly, I’d strongly suggest that the first bush I extracted, which required the planning and efforts of D-Day, had never seen copper grease in its life. Fused rigid. Monsieur Le Grenadier
Post #1056762 9th Jan 2025 11:57am
revd
Advice given to me by a LR suspension guru was to stick with OE, especially for the axle ends of the hockey sticks - they tried polybush at Solihull and were not satisfied with all aspects of its performance. It’s not a job I’m doing for a while so I will cross this bridge when I come to it. The quality of available metalastic replacements will be the deciding factor.
Post #1056770 9th Jan 2025 1:31pm
Grenadier
Thanks Revd. Yup, have heard the poly vs OE argument before, for many bushes not just the ones we’re talking about.
Amusing that you say that Solihull weren’t happy with all aspects of its performance, given they didn’t seem to give a fig about the Defender’s performance for the last 20+ years of its, ahem, ‘development’. More likely than not, the performance they were talking about was in the ‘how is this expensive to build’ vehicle performing on the accounts department’s spreadsheet. In that regard, poly would have been a far worse performer than the parts bin downstairs with thousands of OE bushes already in stock…. Whistle Monsieur Le Grenadier
Post #1056790 9th Jan 2025 3:36pm
ickle
Best of luck with this, I did most of mine 10 years or so ago on a block paved drive in the winter in the UK, but I did have a substantial vice in the garage, also a compressor, an air wrench and a good selection of 'stuff' (but no press) that helped.
Just giving it another birthday / Christmas treat now, clutch, check the intermediate shaft, new 1 piece drive shafts and all new poly bushes, this time in France, in my barn with a very old but functional 4 post ramp - its still a bar steward!
Poly bushes are easier to change than the OE Metalastik but still take some heavy threaded bar and various tubes, sockets and a heavy vice.
On reassembly this time I'm using every single packet of the grease that comes with the bushes, masses of copper slip between bolts and steel sleeves then working spare dinitrol around every joint with a brush to try and keep the water and crud out!
Hopefully be good for another 10 years.
Post #1056823 9th Jan 2025 7:21pm
ickle
P.S. If you can get a full set of poly bushes fitted properly for 600€ in France (2 men x 3 hours x 100€) I'd be amazed!
Post #1056826 9th Jan 2025 7:25pm
Grenadier
Laughing Laughing Laughing
No Ickle, that estimate was for just the rear bushes on the drag links (based on my timings, faffing and that I didn't stop for lunch bang on midday), not the whole bush set!!! Thumbs Up Monsieur Le Grenadier
Post #1057320 14th Jan 2025 12:14am
Page 3 of 4 <1234>
