![]() | Home > Maintenance & Modifications > Ashcroft LT230 1.100 Gear Set |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
Most probably my mistake in that naks didn't say the coolant temp had dropped..that's just me making another assumption😫, and relating the coolant to the mention of a drop in exhaust gas temp...
Still find any drop in running temp odd when adjusting ratios in that way mind, but 20 deg on exhaust temp which can fluctuate wildly is possibly not meaningful.. |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
Great feedback, glad you are pleased with the gear set ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Did you get to fit the larger sump? Puma 110" SW ............................................................. Earth first. Other planets later |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
^ yes, indeed. I haven't looked at the transfer case oil temperatures though.
After a few hundred kms, I have noticed that the pre-fitment drivetrain issues have come back: the clunking when coming to a stop, the vibrations, and the high-pitched whine. The car now also 'grabs' when I come off the accelerator, and where before I could idle in 2nd gear, it now jerks and stalls. So not too sure if the latter is as a result of the different gear set, or if there was a fitment error, or what... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8403 ![]() ![]() ![]() |
Props ref drive train knocks etc? What are they like?
You mean coast at idle revs with in 2nd? Going to that gearstick it won't pull it at those revs and will stall, function of the gearing I would have thought. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Some clunking when coming to a stop, drivetrain vibrations at 2000rpm, high-pitched whine when coming off the throttle
Yep, coast at idle in 2nd, although I do get that this is the new gearing. But the sudden grabbing when I come off the throttle is very off-putting. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Handbrake getting warm? Cheers
^ can't say that I've noticed any increase in temps.
A bit difficult at the moment as ambient is +-40C -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Whine noise probably coming by fitting together new and used gears.
At such high ambient temperature you would be better off using something like 75W-110 gear oil. Not very common oil spec. Puma 110" SW ............................................................. Earth first. Other planets later |
no, the whine was there before.
First we thought it was the rear diff, so we pull it out and fitted new bearings, etc. Then we thought it was the transfer box, so we rebuilt it. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2391 ![]() ![]() ![]() |
Rear diff ring and pinion can whine when worn, did you change those ?
Mo, that's a good question.
It's going in on Feb 10th for the annual service, will ask them. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 682 ![]() ![]() ![]() |
Did you try to run the car without one prop shaft and wirh engaged center diff lock? This way I was chasing broken diff, when car was jus a bit noisy from somethink. I was trying first to find what to look into, than just startin dismantling parts. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Ok, so the handbrake cable was loose, but the one pin was bent, so the handbrake was catching.
It's all getting sorted out, and they are also re-looking at the rear diff whine & backlash. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
