Home > Td5 > 2006 TD5 swivel pre load
AdesTD5
United Kingdom 2006 Defender 90 Td5 CSW Cairns Blue
Hi guys just joined the forum as I’m new to defender ownership and have a slight query. I have rebuilt my swivels with all new components, I have 2 bearings top and bottom(timken) but I’m struggling to find the correct pre load setting. I have left the plate and seal off as per the manual but the Haynes says 3.5kg to 4.5kg but some mention 1.14-1.4 kg. Just wondered what others have used when rebuilding the swivels with bearings and not the earlier bush. It’s a non abs car.
Many thanks
Adrian
Post #1056324 4th Jan 2025 10:19pm
Dinnu
Use the lower values.
The higher values are for earlier swivel pins with the Railko top bearing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1056401 5th Jan 2025 7:16pm
AdesTD5
Much appreciated thank you.
Post #1056403 5th Jan 2025 7:31pm
