Home > Td5 > Defender 15p not starting
Page 3 of 3 <123
Dr Phibes
Australia
Solved. The ECU had lost the injector codes. Seems bizarre but after inputting the correct ones I am back in business!
Post #1056170 3rd Jan 2025 7:11am
revd
Thumbs Up
Post #1056171 3rd Jan 2025 8:18am
rustandoil
Glad you stuck with it... Back on the road 👍🏼
Post #1056173 3rd Jan 2025 8:40am
Dr Phibes
Australia
Actually... I celebrated too soon. It ran and then I tried again and failed. According to the Nanocom the injector codes are being lost. I am going to start a separate thread, and cross-post on the nanocom forum... I have modded the ECU, may be the root cause.
Post #1056177 3rd Jan 2025 9:17am
landy andy
What fuel additive did you run????
Post #1056406 5th Jan 2025 8:35pm
Dr Phibes
Australia
I have traced the problem to ECU and immobiliser issues, so the additive wasn’t a factor. But it was this: https://www.nulon.com.au/products/additive...reme-clean (I am in Australia).
Post #1056408 5th Jan 2025 8:48pm
Dr Phibes
Australia
So it was immobilising… turns out the ECU won’t fire the injectors if immobilised. I took my new ECU and used the excellent mems3 app to set the immo off. I must have Censored up the EEPROM on my original ECU. Will reprogram and solder in a fresh one…
Post #1057803 19th Jan 2025 4:00am
Page 3 of 3 <123
