Home > In Car Electronics > Dodgy Right Headlight, Indicator and Horn. What thoughts?
Grenadier
Evening all.
As per the subject, I’ve got some electrical gremlins I want to sort out.
My right headlight (LED with halo daytime running light that comes on when the side lights are switched on), is currently yellow rather than bright white on the halo setting, and then projecting at funny angles on the main (not full beam), almost as if the light isn’t fully working.
In addition, when I indicate right whilst on side lights, no problem. When I indicate right on main/full beam, doesn’t work at all. And when I first switch on side/full beam, there’s a flicker on the dash board on the turn signal indicator.
And finally, my horn seems very dull sounding. Not a clear toot. In fact dull enough that some people don’t hear it.
This all sounds like wiring/power problem to me. I am a complete dunce when it comes to electrical stuff. What should I be looking for? And where? Dodgy wiring? Crossed wiring? Frayed wiring? Some servo or fuse problem? Etc etc
Help, as always, appreciated Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1053810 4th Dec 2024 5:09pm
landy andy
Sounds like you have an earth fault.
Post #1053816 4th Dec 2024 6:00pm
I think Andy is right, as it’s a fault that appears to be with different common circuits.
So that’s likely to be a high impedance ground.
So perhaps a battery clamp is loose, or the main ground lead is a bit loose on the transmission.
There are the other smaller additional loom grounds on the trans too. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1053877 5th Dec 2024 11:06am
Grenadier
Thank you all. Seemed to have occurred after the gearbox was removed, so could be the one. Monsieur Le Grenadier
Post #1053965 6th Dec 2024 8:22am
That’s likely to be one of those two ground points then, by the time the trans goes back in fatigue sets in. And the grounds are often just nipped up or finger tight which causes issues.
Not guaranteed but you never know, it’s a common scenario.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1053992 6th Dec 2024 2:59pm
Grenadier
Given we put the gearbox and TC back in, then had to remove them all again because the slave was faulty/leaking, we were most definitely ‘fatigued’. Rolling with laughter Monsieur Le Grenadier
Post #1056112 2nd Jan 2025 2:36pm
revd
I recently replaced the main lighting switch and left hand stalk (horn/dip/indicators) on my Td5 because the lights occasionally flickered, headlights (H4) are much brighter now - must have been on the way out for some time
Post #1056118 2nd Jan 2025 3:19pm
Grenadier
Thanks Revd. The main light switch is new (to me) so less than 8 years old, but the indicator stalk is original. Might give it a look if the earth doesn’t change things. Thumbs Up Monsieur Le Grenadier
Post #1056559 7th Jan 2025 3:10pm
