Home > Maintenance & Modifications > LR OEM led lights |
I have LR LEDS on the ICE but I have fitted LED bulbs in the standard lenses on my 90 tdi, work a treat
29th Nov 2011 10:17pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
details please! |
29th Nov 2011 10:34pm |
try this ... http://www.ultraleds.co.uk/automotive-bulb...dbi9df4fs6 |
30th Nov 2011 8:24am |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 |
Has anyone tried these yet?
http://britpart.com/Accessory.aspx?AccessoryRef=4526 Not sure if they fit std holes, or what they are like. Regards Steve |
30th Nov 2011 9:43am |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Hi
Paddocks sells some led lights for LR ... they say in their site that fits all Defenders - some with modification necessary ?! - What modification ? they don't say ... They're cheaper than LR ones ... But it also has on their list something called Smart Load Device 12v ... anyone know what this is It looks like a nice piece of kit ... Anyone tried them ? Knows anyone who has a set ? Do you think it's worth trying ? They don't have that kit with clear lenses ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
30th Nov 2011 11:50am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
You tried this Tig?? Or has anyone else? Reason i ask is i've twice bought and returned led stop/tail bulbs because they wouldnt work correctly on my truck Anyone had better luck on a Defender? [and got a link to proven bulbs] You can get halogen 380/1157 stop/tail bulbs now ... anyone tried those? [or got a link to a supplier]? Guns and Landrovers .... anything else is irrelevant. |
7th Dec 2011 9:36pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
Kit arrived from Tim at mobile systems, everything in there that would be needed including extra foam gaskets for the fog and reverse plinths that remain on the vehicle.
All fitted in less than an hour - probably a quicker job if the umming and aching was taken out. New relay fitted and everything worked perfectly first time, so a bit of a first for me with LR lighting. All lined up nicely using existing holes and cabling so an easy job. Look very nice in clear lenses and very bright which was what I wanted. Yes possibly not the cheapest solution but avoided all the will it work or won't it fit/work scenarios so I'm happy. Might try the led bulbs idea on the older 90 as I want to keep that looking original. Will post some pics up when I get five mins (and not raining) DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
8th Dec 2011 9:15am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Guessing another thumbs up for Tim then
8th Dec 2011 9:22am |
was in Halfods and i notice they do these quick reacting indicator, stop tails etc which is what you must be on about. Not tried any yet. I want to keep the standard light fittings for now so an LED bulb upgrades the best option. i'll buy sme and see how we go. |
8th Dec 2011 9:30am |
noogles Member Since: 07 Feb 2011 Location: Brunei Posts: 34 |
I've been using these without any issues http://www.ebay.com/itm/2-x-Car-Bulb-1157-...3cbeedf942 |
8th Dec 2011 3:06pm |
pjh Member Since: 23 Nov 2010 Location: West Yorkshire Posts: 126 |
If you use LED indicators and replace the relay (rather than using a resistor) what happens if you tow a trailer with conventional bulbs?
Many thanks, Peter Defender 11MY USW |
8th Dec 2011 5:52pm |
Use a 60W relay and all will be fine
8th Dec 2011 7:07pm |
