![]() | Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 39 ![]() ![]() |
So... 13.1 upgrade DONE!!!
but, I used a USED Range Rover Sport screen, so not brand new, I guest has coded for Range Rover Sport... and is a "destructive" method... you need to cut some trims, at lease to install in the way I prefer, there is a kit (powerfull) to do it in not destructive way ![]() so first test used screen is working. IMPORTANT, need to add the 2 adittional power wires (PINS 6 and 7): ![]() Click image to enlarge connect, change CCF, multican 641, couple of reboots and voila: ![]() Click image to enlarge after check everything is working, all images are good, defender model, not RRS!!!... then to finish installation, enter in destructive way... we need to adapt one plastic piece first: cut some space for connectors (in orange) and made new holes to use plastic trim from 11.4 in 13.1 screen: (yes, I do 2 more than I needed.. I take wrong lenght) ![]() Click image to enlarge I need to check lenghts several times, (the idea is keep same bottom position, I add 2 mm to get more space) but at the end I got plastic trim as I wanted (yes, I do 2 more than I needed.. I take wrong lenght): ![]() Click image to enlarge Ok, now I can install screen. but upper trim need some work.... more or less you need to remove this area: ![]() I user a multy tool, first separate the fabric from plastic, and use a piece of metal to avoid cutting fabric, so at the end: ![]() Click image to enlarge put upper trimm and that's all!!! ![]() Click image to enlarge If some of you are interested in my previous 11,4 screen... check for sale area ![]() Cheers!!! |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
I'm now the proud owner of the GAP IID tool and this is on my wish list.
I know that screens from other JLR models will work, but is there a concise list of part numbers for the screens that do work? Looking at ebay there seems to be loads of screen but I'm not sure which to buy, it could work out quite expensive if I keep buying the wrong screen 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
LostCause Member Since: 07 Jan 2025 Location: Toronto Posts: 12 ![]() ![]() |
Thanks for all this valuable info Thunderbob. I was also looking at AliExpress option considering size and the fact it comes with pre wired adaptor and mounts. You mentioned in an earlier post that the screen only powers on when the vehicle is running. So no screen power up on just entry to vehicle and such. Was this still the case once you had it coded correctly? I have a v4 Gap tool already was this what you used for your original coding that did not work? |
Beautiful job Clark4x4! Thanks for sharing all this info. I'm also reviewing options to upgrade and your posts have been very helpful. |
ThunderBob Member Since: 23 May 2024 Location: Kentucky Posts: 20 ![]() ![]() |
@lost cause The screen powers on and off exactly like the OEM screen; ![]() Click image to enlarge there is no difference. When I used my Gap tool (v4 with latest firmware) the screen acted just like it would if I had the wrong screen size entered in the CCF ie like the screen was not powered on. When I reverted back to the original CCF setting the screen powered on albeit with the slightly stretched display. When the vendor made the change’s remotely via my laptop, I could change the resolution via the screen change as shown on my original post. No need to change the wiring or use an adapter. Not as satisfying as @Clark 4x4 solution but much easier and the end result essentially the same. ![]() Click image to enlarge |
Thanks for the reply ThunderBob. So just to be 100% clear even before starting the ignition when you get in the vehicle the after market screen will power up to the land rover splash screen? if so this is awesome news. Makes me wonder if there is an additional value besides the screen size in the config file that is being changed by the vendor of the screen. If size is the only setting for an OEM screen to make it work one would assume. Sorry for all the questions I do have one more. When getting the vendor to remote in to make the changes are they always available or do you setup an appointment.
mikesdnielsen Member Since: 27 Oct 2024 Location: Aalborg Posts: 4 ![]() ![]() ![]() |
Thanks for all the great information in this thread.
I've been on the same journey over Christmas. I bought a brand new 11.4" screen from a supplier in the UK. I did the coding using the my IID Tool, but I was not able to get the screen to coded. Coding and "hacking" Defender is not a big thing here, I think as it's a very small market for this type of car here. I've just had it with the local Land Rover workshop, and they were also not able to get it coded straight away. They'll try it again using one of their newer Defenders that were "born" with the 11.4" screen (it was unfortunately out). I'm also in dialog with GAP about how to possibly solve this, in case the dealer comes back unable to do it. Mounting the screen with the Powerful UK custom bracket as a breeze though - I can really recommend this as it seems very easy to use. |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 184 ![]() ![]() |
hello,
When you buy a NEW screen it must be programmed with Pathfinder or topix cloud, tools that the land rover dealer has. For programming it is necessary that you FIRST tell the car that you have an 11.4 screen, (with the Gap tool you modify ccf), then THEN you go to the dealership with the new screen installed, connect topix cloud, idma-interactive display module A, module programming, module replacement, run, and it performs the correct programming. Marco |
Thank you, Marco! I'll try this with them. I really appreciate it! 🙌
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 366 ![]() ![]() |
I think it will be your lucky day if the dealer cooperates with that!! I insist, anyway…Good luck!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Thanks to ThunderBobs post on his AliExpress find I was able to upgrade my 10" to a 13.3" screen today. Overall it was 1.5hrs taking my time to complete end to end. Watched the screen removal video from PowerfullUK for the disassembly. As far as the new screen goes I'm impressed with the adapter bracket which i think beats other options for retrofit hands down. Also the build quality seems to be no different to OEM and the screen resolution and color is excellent. I found with the OEM 10" Panasonic the touch was less responsive with the new aftermarket being much faster. Once installed I used my gap tool to update the car config to the 11" screen size and then performed a PIVI reset. Once everything came back up I swiped up from the bottom of the screen for the hidden menu to select 11.6". Totally improves the look of the vehicle and makes for an easy to quickly read screen while in motion. Maps and media are massively improved on the additional screen space. 10/10 from me for this plug and play upgrade.
Package contents (adapter bracket, side brackets if upgrading from 11", screen, clips, cable to program if you dont have a gap tool) ![]() Click image to enlarge OEM 10" removed ![]() Click image to enlarge Adapter mounting bracket installed ![]() Click image to enlarge Screen updated to correct resolution ![]() Click image to enlarge Side view of bracket and screen to show fit ![]() Click image to enlarge |
Great assembly and update, I like the look of the car with the little one but I recognize and must admit that it is insufficient from the practical and real point of view, especially if you have presbyopia, it is too close, it has turned out very well and I see that it “only” took 1.5 hours of work, so the only detail missing is, can you indicate what the total cost of the operation is?, screen included, if you want of course! Thanks and enjoy!!👍🏼 Defender 110 SE I6 D250 23MY
Hey Ruben,
The screen kit I picked up was about $780 CAD. But the price does fluctuate. I’m kicking myself for not picking up around Black Friday as it was $650 CAD then. If you research how you can use the cable the kit comes with so there is no further cost. You can also contact the vendor and they will do it remotely for you. I already had a gap tool for other software unlocks I had done. That cost about $900 CAD but not essential for this upgrade. Going the OEM route with just the 11” the screen new is about 2k and all the plastic parts run about $400. You would then still need a cable adapter. Plus with either the 11 or 13” screen you may have to modify the top dash rail a little to get the fit right. For all the how to bits I recommend the powerfuluk videos. They’re entertaining and they take their time explaining everything. |
Thank you very much LostCause for your kind, and fast, reply!! 😉 Defender 110 SE I6 D250 23MY
