Home > Td5 > electrical connector crimp pins
alexatnd
Defender TD5 electrical connector pins ... are most of them the same?
Hi,
Electrical connectors for rear indicators/rear lights/ fog lights / reversing lights located in rear corners of defender 110. All the pins look as if they're the same size.
Can anyone point me at where I can buy some?
Also need replacement pins for odbc socket
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1055580 24th Dec 2024 6:01pm
Mdm
i know martyn supplies them
but i use simtek as they are near us.
send them a pic, and some info and they can normally identify the make of plug from that.
https://www.simtekuk.co.uk/
very good to deal with
Post #1055590 24th Dec 2024 7:17pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
Econoseal connectors are what your looking for. Durite does them.
Post #1055870 29th Dec 2024 10:14pm
rustandoil
Econoseal, but there are different types
Post #1055881 30th Dec 2024 9:01am
alexatnd
Many thanks for the replies.
My odbc socket was looking a bit trashed so thought id replace it... except you cant get it any more, seems to have been replaced with C2S32215. Tried an econoseal socket from a 3 pin socket ... doesnt fit.
Have emailed simtek.co.uk to see if they can help. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #1056458 6th Jan 2025 4:34pm
rustandoil
Post #1056474 6th Jan 2025 6:42pm
Martin
Site Admin
I can supply the terminals for the OBD socket from stock.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1056475 6th Jan 2025 6:59pm
ELVIS
I have boxes of OBD connectors/pins and also the covers to keep dirt out of the pins.
Message me if you get stuck. Think I buy them in at £2 per socket/cover.
Pins for other plugs will probably be JP/JPT. About £6/50 for known/decent supplied ones that crimp and seal properly. 1999 TD5 110 CSW
Post #1064298 31st Mar 2025 12:53pm
alexatnd
many thanks for the offer. I actually revistited the earthing round the ECU. Put an earth from ecu to body, then another one from battery to the seat box on the other side. Plugged in the nanaocom I'd just bought and everything worked just fine.
May actually revidit the odbc plug at some point and replace with new one but other things to do at the moment Smile
Post #1064313 31st Mar 2025 3:35pm
