![]() | Home > Puma (Tdci) > Oversteer or Understeer or what? |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
all of the above.
under steer into over steer into the hedge ![]() slow in fast out....bit like sex really! |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
In a very old 90 with 265/75R16 mud pluggers on when its snowing with ice under you get oversteer. A 110 my be different with there being more weight on the back axle but i would say the same thing would happen, just need to push it more before the back end makes a bid for freedom! lol.
Pete |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Depends if you have anti-roll bars.
Rear ARB only = oversteer (lift-off, which would be pretty hard to achieve in a Defender) Front ARB only = understeer Both/no ARBs = the wonderfully balanced normal handling of a Defender ![]() I did try to get my old 90 to slide on a roundabout in the wet (on private land, officer). It did eventually 4-wheel drift, but only once the body had rolled so much that you could only see tarmac out the left-hand window ![]() |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
I did wonder about the 4 wheel slide as I watched a clip on you tube - fastest defenders - but as you can imagine none of them appeared to have standard suspension. 2008 110 XS CSW Stornoway Grey
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
I've drifted mine before but it's pretty hairy. Not recommended.
They do grip surprisingly well though. Defender 110XS SW gone... now VW California 180 4 Motion. |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 883 ![]() ![]() ![]() |
Recently saw the following sticker on a trials car (not strictly accurate, but fun):
Understeer = You see the wall you’re gonna hit Oversteer = You don’t see the wall you’re gonna hit Horsepower = How fast you hit the wall Torque = How much of the wall you take with you Peter |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5893 ![]() ![]() |
I find you can get over, or under steer depending on the speed and amount of volume you are exerting.
Four wheel drifting is a great hobby and well worth a practice. But don't worry your bum will fail way before it tips over, I have tried ![]() ![]() Andy |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
How many owners will be practicing their drifting skills on the local Morrisons car park on snowy icy evenings...
Morrisons?! ![]() I say old chap, we don't take our Land Rover to such peasant hangouts... ![]() Mind you, the M&S car park is a bit small... Defender 110XS SW gone... now VW California 180 4 Motion. |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
To decide between understeer or oversteer, the defenders steering would need a thing called direction power instead of suggestion question, which is what you usually transport as wish to the steering. Never forget: cars have owner, Landrover have field service personnel.
![]() you don't buy defenders to go fast anywhere ![]() ![]() |
Mullen Member Since: 31 Aug 2011 Location: West midlands Posts: 93 ![]() ![]() |
I can't get my 90 to slide?! I usually crap myself and let off as it rolls to much!
I did come from a cooper S on coilovers though! |
![]() ![]() Quite agree bpman, Defenders are not for fast driving, but occationally a corner tightens or is sharper than you expected, so a little knowledge gained might save me! Where's that lovely snow! ![]() Fiddlesticks - messed up the quote ![]() |
