![]() | Home > Puma (Tdci) > Alarm going off intermittently |
revd Member Since: 20 Apr 2024 Location: England Posts: 272 ![]() ![]() |
take care, some ner-do-well may be waiting for you to disable the alarm
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Does it start ok in the morning? As it could also be the battery voltage dropping too low, and the battery backup sounder BBUS would trigger. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
YB64RUU2015 Member Since: 25 Feb 2024 Location: Staffordshire Posts: 8 ![]() ![]() |
I thought initially it was someone messing with it but it’s blocked in by other cars and no lights going off just the alarm sounds and goes on and off for about 5 minutes. Didn’t disable when I took the negative cable off but stopped when I removed positive terminal
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
What voltage is it sitting at, at rest? It could be dipping below the threshold that it likes to see. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2426 ![]() ![]() |
Check your door and bonnet switches to see if they are working correctly and the terminals etc are not corroded.
Also have a look at your Alarm Locking Module (ALM) unit to see if it is wet and the two connectors going to it are properly seated. You can see the unit by removing the drivers footwell speaker and looking up at the bulkhead. |
Thanks I need to check but relatively new battery and never any issues starting lights never dim.
Cheers that sounds like the most plausible as had some water leakage coming in to o the footwell. Many thanks to all responses and will update when I find anything. I am thinking of fitting a Scorpion after Christmas |
Given its a new battery, make sure the cables are clamped well to the battery terminals. Easiest way is to loosen off the clamp and gently tap the clamp down on the terminal with a hammer and drift. Then torque up the clamp bolt.
Cheers first thing I did and we’re all tight and pushed into terminals.
Is there any draught setting off the internal alarm? The volumetric sensor I think they call it?
Or it could be faulty if there is one fitted. Failing that, a door or bonnet sensor is degraded that possibly the wind at night is jiggling it around, less likely if in closed garage though. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
I have a 2015 90XS Station Wagon and I had exactly the same problem when it was a couple of years old. The only way I could stop it sounding was to disconnect the battery. Turned out to be the BBUS was faulty. Defender 90XS SW
BBUS Battery Back up Sounder - anyone know if these are available as no one seems to stock them. Is it possible to remove them or do they cause an issue to stop the alarm going off randomly until I can get a replacement system
I think your answer is in this thread: https://www.defender2.net/forum/topic65058-15.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I did look at that thread but it doesn’t say it stops the issue by removing it or where you can get a new one other than LR who say not available
