![]() | Home > Puma (Tdci) > Stainless Bolts etc |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 ![]() ![]() ![]() |
The door and bonnet bolts are not exactly high strength bolts. If you were going to use them for fastening down winch bumpers, recovery points then yes it would be a good idea to use high tensile bolts rather then stainless.
We have just got some of the Nakatanenga stainless bolt kits in. Look here They do come with genuine Land Rover heads on, plus a tube of paste. They may well cost more then the sets on ebay, but if you want that type of set you might as well pop along to your local screwfix or bolt merchant. I now duck and run for cover ![]() Brendan |
The problem im having with that site that you posted is the fact that i cannot translate german ![]() ![]() |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Bought a set of SS rear crossmember bolts (well just above them) but not fitted them yet as I'm not convinced of the corrosion resistance - only one pair has corroded too - SS mixed with galvanised might look a bit odd.
It's all about the potential difference/reactivity of the metal - the larger the difference, the worse the corrosion. So you need to isolate any different metals - sadly a LR is made of steel and alu which sit a fair way apart on the reactivity table. ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
![]() ![]() My translation tool is from Google if you use Google, does it automatically! ![]() |
Iv never used ACF-50 before...Is it clear or black when sprayed ? Would you recomend i spray the whole bolt or just the head as it will be the most exposed ? Cheers |
Just the exposed heads, sprays on clear. Copper grease is the stuff to use on the threads
NIce one ![]() |
bolampau Member Since: 06 Jan 2012 Location: Lincolnshire Posts: 100 ![]() ![]() ![]() |
Sorry to hi-jack the thread. I get my MY08 Puma 110 this week (can't wait!) and first job I want to do is remove the two third row seats to clear the rear load area.
Would it be sensible to use stainless steel grub screws + copper grease to fill the holes - I believe they are M8 size? Obviously I don't wanna encourage corrosion. Thanks for your help, Paul |
SS bolts if AISI316 do not rust itself!!!
It is not a problem of rust, is a electro corrosion problem But it is very important to use a very good "ANTI SEIZE PASTE" for eliminate the electro corrosion induced by the difference of the potential that born from two (or more) metals. eg. Galvanic series in seawater at 25°C (77°F) are indicated below Upper position = better resistance Platinum Gold Graphite Titanium Silver Chlorimet 3 (62 Ni + 18 Cr + 18 Mo) HASTELLOY®; alloy C (62Ni + 17 Cr + 15 Mo) INCONEL® alloy 625 INCONEL® alloy 825 Stainless steel, type 316 (passive) Stainless steel, type 304 (passive) Stainless steel, type 410 (passive) Monel alloy 400 INCONEL® alloy 600 (passive) Nickel 200 (passive) Copper alloy C71500 (Cu 30% Ni) Copper alloy C23000 (red brass 85% Cu) Copper alloy C27000 (yellow brass 65% Cu) HASTELLOY® alloy B INCONEL® alloy 600 (active) Nickel 200 (active) Copper alloy C46400 Copper alloy C46500 Copper alloy C46600 Copper alloy C46700 (naval brass) Tin Lead Lead-Tin solders Hastelloy A Stainless steel, type 316 (active) Stainless steel, type 304 (active) 50 - 50 lead tin solder Stainless steel, type 410 (active) Cast iron Wrought iron Low carbon steel Aluminum alloy 2117 Aluminum alloy 2017 Aluminum alloy 2024 Cadmium Aluminum alloy 5052 Aluminum alloy 3004 Aluminum alloy 3003 Aluminum alloy 1100 Aluminum alloy 6053 Galvanized steel Zinc Magnesium alloys Magnesium SO if you put toughener AISI 316 and Alluminium alloy1100..... this last one will be the sacrificial anode ...... See the magnesium billet on the boats. You must build an electrical isolation (not metallic/physical) from the metals. Who own a old defender can remember the problems with the Steel frame/alloy skin doors..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
You can get plastic (nylon?) bolts.
Is it possible to get plastic grub screws? Or get a nylon bolt if need be, cut off head and hacksaw a screwdriver slot in it. That way no electrolytic corrosion Brendan |
Dgardel
Wow, thanks for the technical explanation. I've had Disco 1's in the past so can now appreciate what electrolytic corrosion looks like. Brendan Good idea re. the plastic bolts/grub screws, will see what I can get hold of. Can anyone confirm if the seat bolts are M8 size please? Thanks for your help, Paul |
plastic or nylon bolts have not the mechanical resistance needed.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I think he only wants to block the holes up when the seats are removed so it doesn't matter. ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
