Home > Puma (Tdci) > Vibration with hard throttle in 6th
Page 2 of 3 <123>
T1G UP
AndrewS wrote:
The best fix would be a TDV8 with auto box and transfer case, Followed by aftermarket props, diffs, drive shafts etc etc
i'm with you on that one!
To low revs for the gear! 1500-2200 max boost at those revs so max torque and it's struggling to pull it! You lot invent half the problems Rolling with laughter
Post #105494 8th Dec 2011 10:49am
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Low rpm , high gear and you're asking for issues on any powertrain. The forces you're inflicting are significant.
Change down or buy a steam engine.
Stu
Post #105497 8th Dec 2011 11:16am
ZeDefender
LROV90 wrote:
I too have the same juddering. I also have the BAS remap and the juddering only happens with the remap running. Thinking it might be the clutch slipping with the extra power??
Try putting the standard file back into the ecu and see if the juddering goes away.
Exactly! I have an Alive remap on my 110 SW and the first "untamed" version caused heavy juddering between 1750 and 2250 rpm in 5th and 6th and only when putting my foot down. Also only with the remap.
Gary at Alive seems to think it's from increased torque, possibly to do with the front prop vibrating - capping the torque in those problem areas seems to be the solution (sorry Gary if I'm talking boll*cks Wink )
He has been incredibly (!) patient with me and we almost have it sorted. Truck is now very usable and has plenty of smooth power all the way up. Just a little judder through 2000 rpm in 5th and in 6th from 1500 to 2100 rpm when pulling (and yes, sometimes I do drive uphill on the Autobahn in 6th at these rpm).
I am very confident Thumbs Up Tell someone you love them today because life is short.
Post #105503 8th Dec 2011 12:23pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I have the cause of this!
Post #287732 4th Dec 2013 9:26pm
ZeDefender
That would be very interesting Thumbs Up
A long time since my last post and I have ended up with the Version 2 BAS remap on my 110 (long story) - the juddering is hardly noticeable even on the "untamed" map, as the power/torque distribution is already very refined.
That being said - what's the cause? Tell someone you love them today because life is short.
Post #287758 4th Dec 2013 10:17pm
Cheshire110
despite being noisy and having lots of low end torque, the tdci lump does need to be worked IMO
defenders already have chocolate drivetrains, don't make it worse by using 6th less than 2000/2200. that feeling of almost stalling destroys clutches in all cars, especially defenders. after needing a new clutch Im now keen to keep it going Smile
mpg and engine life are actually better if you stay in the right gear, its not just about keeping RPM down... Cheers, David
Post #287761 4th Dec 2013 10:24pm
ZeDefender
Agreed but shaking in 4th at 2000 rpm (not lower or higher) just ain't right... Tell someone you love them today because life is short.
Post #287784 4th Dec 2013 11:28pm
Cheshire110
Hmm yeah..
Any rattling at tickover with clutch engaged? (Pedal up) Cheers, David
Post #287788 4th Dec 2013 11:33pm
ZeDefender
No rattling but slowly getting noisier though Sad
Still 6 months guarantee - not sure if I want the clutch to go before then or not... Tell someone you love them today because life is short.
Post #287791 4th Dec 2013 11:35pm
borderterrier
Sorry been busy. Intercooler hose fouling steering shaft. Under boost the turbo spools up and vibration is transmitted to, and amplified by the steering.
Post #288209 6th Dec 2013 8:03pm
ZeDefender
Cheers - that's one I'll check out tomorrow - too sodding cold to get the torch out now Evil or Very Mad
But might it be different with LHD?
...Oi need to learn me sum anatomee Whistle Tell someone you love them today because life is short.
Post #288230 6th Dec 2013 8:51pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
In a tall gear and putting foot down will put the full engine torque on the drive train. With a remap you are probably getting a 25 or 30% increase in torque putting even more twisting action into the mechanicals. Anything that is loose, badly worn or out of balance in the drive train will cause vibration. U/Js etc. I have had it on other cars where wheel balance was brought into question under high torque conditions - despite my disbelief it was resolved once balanced.
Peak torque is at the rev ranges reported.
You could try removing either the front or rear prop, locking the centre diff and going out for a run - that will help you eliminate or prove which end of the truck is causing/not causing it
Post #288387 7th Dec 2013 3:02pm
Porny
Site Sponsor
200bhp/560nm and no vibration issues in any gear..... Wink with a standard drivetrain. This is from 1500rpm upwards... infact even from about 1300rpm....
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #288947 9th Dec 2013 8:26pm
bell-auto-services
Some people in the past do tend to get used to the good extra torque and start driving a little "lazy" in 6th , polite note to all. Make sure you use the gearbox and revs for what they are designed for and it won't happen in most cases. Thumbs Up
Allow it to rev more in gears before selecting the next, and select the correct gear for the traveling speed and torque vibration won't generally happen. Of course cars with bad clutches, warn prop joints, dodgy diffs etc or lifted suspension can cause the same effect as well as an array of other mechanical faults.
My 110xs 2.2 with the same power Ian's 2.4 90 does not do it at its 200bhp and 560nm but I do allow it to rev in gears more than most and don't select 5th or 6th at a to low speed and so do not induce it.
That said not sure how long the box will last with that amount of torque going through it lol as they do in places inside them seem to be made of toffee when we stripped one a few months ago for some internal upgrades we are on with Thumbs Up
Regards Pete.
Last edited by bell-auto-services on 9th Dec 2013 11:12pm. Edited 12 times in total
Post #288986 9th Dec 2013 10:33pm
bell-auto-services
I had a car like this a couple or years ago, typically it was by pure fluke I found the exact same thing. I've also had a few with water in the fuel or contaminated fuel causing some very weird problems from knocking and tapping to vibrations on engine revving when under load.
Pete.
Post #289002 9th Dec 2013 10:57pm
Page 2 of 3 <123>
