Home > Technical > Penman Trailer Brakes
muppetlab
United Kingdom 1994 Defender 110 300 Tdi HCPU Arrow Red
Hi. im new to the forum but have been around landrovers for too many decades. Im looking for help with a penman trailer, specifically the brakes. A recent purchase is missing a caliper and i really want to go through the brakes and ensure its all good. The only issue i have is where to get parts? ive done a search and there is reference to the parts being citroen Xantia but which model and what are the brake discs? Citroen or Defender? its got wolf wheels so im guessing its a land rover hub and brake disc? any help would be appreciated as the trailer project had come to a stop as im now without brakes Sad
Post #1054859 16th Dec 2024 4:58pm
Andy RV
I can’t answer your question on the caliper sorry however here is the parts list which should help with the disc information, the calipers are shown however other than a basic description it doesn’t appear to help;
https://lrxd.org/documents/lrxd/aesp/trail...ALOGUE.pdf
Post #1054887 16th Dec 2024 9:29pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
There is a very helpful group on facebook called the penmen sankey owners that has alot of information about the brakes and bearings etc 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1054910 17th Dec 2024 12:14am
muppetlab
Thanks, parts are limited and the surplus guys dont want to help source civi parts. ive worked out some parts i think but wont know till they arrive if ive made a big mistake. cheers
Post #1054911 17th Dec 2024 12:21am
rallysteve
Calipers and brake pads (EBC DP1077) are Citroen but sadly the discs are not direct fit from any other vehicle from what I found when I had one. I think you could get away with the Citroen discs but would have to re-drill them to suit the PCD of the bolts which hold them to the Penman hub (same way Defender discs are mounted). From what I recall the O/D of the disc and thickness matched the Citroen ones but I never checked the offset or mounting PCD.
Unless your discs are really badly worn or pitted I would just clean them up or get them resurfaced.
Post #1054939 17th Dec 2024 1:13pm
muppetlab
Thanks for confirming the part number. The offset isnt citroen as far as ive found but im still looking. just want to future proof the trailer while i can get some parts. cheers Jez
Post #1054957 17th Dec 2024 5:10pm
rallysteve
In that case, for reference: the hub seals are freely available from seal manufacturers (i used SKF) and are 60x90x10 HMS5 RG.
I think the originals are double lip and the above part number is single lip but it wont make any difference whatsoever for normal use of the trailer.
The side reflectors are Rubbolite M78: https://www.dun-bri.com/Brands/Rubbolite/R...-Reflector
Rear reflectors are Rubbolite M171: https://www.dun-bri.com/Brands/Rubbolite/R...w-In-152mm
If you need new tailgate buffers I found a source and bought some myself but cant recall off the top of my head what they were but can look back through my invoices if you need?
Same with the front marker lights. They are no longer available but there is an look/fit LED version you can get now (but quite pricey).
Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #1054966 17th Dec 2024 5:56pm
muppetlab
Hi, thanks for the part info thats fantastic. i havent pulled the hubs yet to regrease the bearings but will defo keep some seals ready for when i do. I havent checked the tailgate buffers but will do next time i pull the trailer out. Thanks for pointing me in the right direction. Very Happy
Post #1054979 17th Dec 2024 9:29pm
