![]() | Home > Modifications & Maintenance (L663) > Wipers too Long? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1273 ![]() ![]() |
are you sure the wiper arm, not the blade, is in the correct position
Chris_P Member Since: 13 Dec 2024 Location: Montgomery, TX Posts: 6 ![]() ![]() |
Could be incorrect; trying to figure if that might be the isssue. Looks like it was the same arm that was sold when brand new. I have a close up picture of this vehicle in action at the TReK event before sold from the dealer. Maybe it was damaged before this picture and replaced with another model LR.
![]() Click image to enlarge ![]() Click image to enlarge |
R1 paul Member Since: 30 Dec 2022 Location: Hungerford Posts: 7 ![]() ![]() |
22” is correct, I bought some from LR parts. Think they also fit a VW Beetle
You may be correct. I have a sneaking suspension that the arm was set wrong in the past and the splines in the arm are damaged. I took a stab at re-clocking and it’s not hitting the A-pillar trim but a little higher than I would like. Since the splines are damaged, seems it can only be either a bit too low or a bit too high, but good enough now. |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 450 ![]() ![]() |
Bosch A889S 57,5 cm = 22,63"
![]() Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
