![]() | Home > Maintenance & Modifications > Dash Screws, AlliSport + Nakatanenga, Protection Plates |
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786
Had a few email back and forth with AlliSport and Nakatanenga. Apparently the Nakatanenga hose from their RAI is 80mm and goes to the adapter from 80mm to 90mm which then plugs into the airbox.
AlliSport on the other hand, uses an 89mm flexible hose that goes to a reducer that shrinks the 89mm to 76mm to fit to their waterproof airbox. Looks like it will be a chore to link up the two. Or can I stick with Nakatanenga's 80mm hose? is the 9mm difference going to be an issue? Thoughts? No Better Friend, No Worse Enemy |
Hi All!
The dash screws on the side that screw onto the A-pillar, the six (?) small ones, what do they screw into? Need to replace those and the actual screws. Anyone have the part numbers? Thanks. No Better Friend, No Worse Enemy |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
I believe that the six screws are FYP500570. They're thread-forming screws and as I recall they screw into a plastic insert in the A-pillar, but I cannot find any insert anywhere in the electronic parts catalogue. I'd have to dismantle my dash to be sure (and I'd rather not do that).
Re. your earlier question, I would have thought that is should be fairly straightforward to seal a Nak 80mm hose directly to an Allisport 76mm spigot, the difference is not great and it wouldn't be hard to wrap the spigot with duct tap if necessary to make it larger. |
Thank you, blackwolf!
That's the information I need! Would anyone know the part numbers of the plastic inserts the FYP500570 screws go into? Need to replace them. No Better Friend, No Worse Enemy |
