Home > Maintenance & Modifications > Fitting speedo healer to Td5 Defender
Page 2 of 2 <12
jonny
A quick search suggests that pin1 on the back of the speedo is the speed output to the ECU. Yellow/Pink wire.
Pin 13 on the Engine ECU (Black C0658) is linked to the instrument pack by via connector. Yellow/Pink wire.
See: https://nas-row.com/index.php?threads/td5-...#post-7006
Post #1054499 12th Dec 2024 3:47pm
Pepsyseventy
Switzerland 2001 Defender 90 2.5 TD Tomb Raider LE Bonatti Grey
Thanks, I’m very basic and I would appreciate if you can specify more which cable of the dash goes with which cable of the speedo healer, thanks a lot!
Post #1054500 12th Dec 2024 4:01pm
jonny
I would imagine that your speedo healer has 4 wires : positive, negative power feeds, a wire that goes 'in' for the speedo input, and one that comes 'out' for the altered speedo signal.
you need to connect the 'in' wire to the 'speedo' side of the yellow/pink wire, the 'out' to the ecu side of the same wire.
I would probably suggest taking it back to your mechanic and getting them to change it for you...
Post #1054501 12th Dec 2024 4:05pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Harry.O wrote:
The red cable on the Speedohealer needs an ignition live, the black cable needs an earth. I cut the yellow/white ECU wire coming from terminal B13 on the black ECU plug, connected the white wire to the speedo gauge end and the green wire to the ECU end.
This should be the information you need.
The Speedo effectively doubles the pulse count coming from the Speedo transducer on the transfer box. Speedo transducer produces 4000 pulses per mile, Speedo then doubles that to 8000 pulses per mile which the ECU needs to see within a certain range depending on speed in order to use the cruise control. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1054503 12th Dec 2024 4:11pm
Pepsyseventy
Ok top!! thanks
Post #1054538 13th Dec 2024 7:56am
Pepsyseventy
Thanks all I will try to fix it!!
Post #1054539 13th Dec 2024 8:00am
jst
jonny wrote:
The TD5 ECU expects a certain ratio of revs to road speed for cruise control to engage, which is based on a 1.4 transfer box.
If you put a 1.2 transfer box in, the ratio changes which means CC won't engage, as the ECU thinks there's something wrong.
The solution is either to fit a speedo healer between the back of the speedo and the ECU to 'fool' the ECU, or to adjust the ratio within the ECU itself via nanocom or similar..
Great explanation, thank you. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1054545 13th Dec 2024 9:17am
TexasRover
Quick question: I you fit an overdrive, I suppose that relationship between expected RPM for MPH will also be messed up and so the solution would be to fit a speedohealer (or Nanocom correction) tuned for OD engaged since that would be to most used setting for Cruise Control to be operated?
Post #1054576 13th Dec 2024 11:54am
Hazza
Yes that would work - I'd imagine that with some basic wiring you could only have the Speedohealer switched on when the overdrive is engaged, so you'd be able to use cruise control both with and without overdrive engaged.
There are some cheap Speedohealer alternatives available on eBay too:
Post #1054580 13th Dec 2024 12:14pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
jst wrote:
Just for my knowledge.
Speedo healer but not used to adjust the speedo. So what role is it used in here ? Presumably a 1.2box gives wrong output speed to a cruise unit and this adjist it?
That's correct, or in my case, a v8 5th gear ratio fitted to the recon gearbox which was sending pulse signals outside of the parameters that the ECU liked. CC would engage then disengage after 2 or 3 seconds. 6 years later and the little Speedohealer is still working perfectly, interestingly it has never needed resetting since installation, despite being left for months with a totally dead vehicle battery Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1054618 13th Dec 2024 8:58pm
Page 2 of 2 <12
