![]() | Home > Td5 > Injectors push till click or torque down fixing bolts |
stark Member Since: 09 Mar 2021 Location: UK Posts: 30 ![]() |
I recently did mine and the effort to 'click' them didn't seem too great, suggests maybe the washer has moved and is blocking them from going down all the way? Quite a few of the washers moved and / or dropped off as I was fitting the injectors back in and had to take them out / retry until they went in correctly and gave the satisfying click.
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
hmm ok.
Certainly took them out and checked position of washers and put them back in. torquing down the bolts certainly moved injectors in a lot and. shes running fine. Having said that all the other times did have the satisfying click when i pushed them in. certainly staerts and runs fine, just need to get the new injectors coded in now burt will keep an eye on oil level in c ase it goes up rgds A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
