Home > Tdi > 200 power steering quirk.
Mining Subsidence Stu
United Kingdom 1991 Defender 90 200 Tdi HT Caledonian Blue
Steering box was leaking. Got it replaced with a very expensive one.
Had the fan belt snap, which then took the power steering belt off as well a mile from home. Drove it home with brute force.
Put new belt on, belt has started slipping, mainly when I start it up and at low speed. Sprayed it with belt jizz and have tightened it up and it still seems to like slipping.
I've got to do a big road trip tomorrow and I'm a bit anxious about it. It's ok totally, PS works no problem at all, but at low speeds it's slippy, seems to be turning left is more of a problem.
Am I right in thinking the "blow off" or "pass" valve is Censored and I need a new pump?
Presumably this is something many of you have dealt with.
Cheers Stu
Post #1054241 9th Dec 2024 1:21pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I had a 200 tdi and the belt had to extremely tight for it not to slip and squeal. I believe that new belts and pulleys will solve the problem and then presumably they won’t need to be as tight. I just put on new belts and kept it very tight, although this wouldn’t be beneficial to the bearings in the items run off of said belts. It would be easy to check the bearings on the alternator/ pas / water pump as check. I seem to recall buying a different make belt, or maybe a fatter one, but not certain on this. 1983 110 automatic OM606
Post #1054286 9th Dec 2024 10:44pm
tightened it right up and it was fine (new belt). Started squealing again FFS. Time for a new pulley.
Post #1054593 13th Dec 2024 3:08pm
Dinnu
Was it happening before you ‘forced’ the box?
I never opened a PS pump, but I know there is a lot of valving done on the input shaft of the steering box. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1054595 13th Dec 2024 3:13pm
Mo Murphy
After a new belt and pulley, you will need to retension the new belt again as it stretches.
50 Shades of Pennine Grey
Post #1054605 13th Dec 2024 4:25pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
I had this problem for ages.
Turned out the pump was slightly loose and kept moving.
Had to re-tap the holes and new bolts.
Bought several different size belts to make sure of good fit, original was too tight.
Post #1054650 14th Dec 2024 10:32am
Yep. Just went and swung on the bolts. They need re-tapping. What did you use size wise and presumably you had to drill the plate as well. I may use studs due to fear of the same thing happening.
Post #1057663 17th Jan 2025 3:02pm
Bowbearer
Luckily my neighbour is an ex aircraft engineer and builds his own cars,
I pop round and ask if he has anything and give me the tap and new bolts.
So sorry can’t help with size.
Studs sound a good option, I think at one time they sold studs for this very problem?
Post #1057680 17th Jan 2025 6:30pm
