Home > Puma (Tdci) > The Big Bang
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
The Big Bang
As so many stories start, I was just driving along….
When there was a bang followed by a loud thrumming. I was doing a 100 kph so slowed down and pulled over. Just before stopping there was a cloud of coolant steam from under the hood. I set up the warning triangles and then crawled under for a look:
Obviously we weren't going anywhere so I called a tow truck and arranged for a rental truck and car carrier to haul it home. Then up on the stands for a closer look. Here's the culprit:
The centre joint's locating ball failed which turned the mild mannered shaft into one of the greater demons. First it did the transmission oil level check, then it took out the LHD T/C mount which caused the powertrain to drop which sheared a stud or two off the exhaust manifold, ripped a coolant hose off, and otherwise had a jolly time till I ground to a halt.
Moral of the story? Not sure... maybe beware of fancy driveshafts?
Post #1054114 7th Dec 2024 9:39pm
Ianh
That should just polish out Very Happy
Seriously though, glad you did not suffer a major crash with the prop letting go at that speed.
I assume that double Cardan is a front prop ? Which make was it ?
Post #1054115 7th Dec 2024 9:54pm
landy andy
The prop looks complete. Did its bolts come apart?
Post #1054116 7th Dec 2024 9:56pm
jbcollier
Yup, polish on order.
Yes, it's a double cardan shaft from a reputable supplier. It's (was) even a HO shaft.
Nope, bolted tight. The centre ball between the two joints just let go.
Post #1054118 7th Dec 2024 10:41pm
Well, you found out what the bracket on the cross-member is for - catching the transmission!
How old was the prop shaft? Has it been serviced regularly?
Quite worrying since I have a similar prop in the same colour and probably from the same supplier.
Post #1054120 7th Dec 2024 10:58pm
jbcollier
The shaft was fresh and religiously greased.
There is another possible scenario:
That the LHD mount failed first which dropped the powertrain and then the shaft centre ball broke due to the impact. Bit of a chicken and egg situation.
Post #1054121 7th Dec 2024 11:04pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
Yikes! I hope it was the mount that let go. I have a front prop that look remarkably similar.
Rolling Eyes 2011 130 Utility Body
2005 110 Van
Post #1054126 8th Dec 2024 12:53am
jbcollier
I'm switching to a lengthened D2 front shaft.
Post #1054127 8th Dec 2024 1:12am
LR90XS2011
I feel for you not great at this time of year DEFENDER 90 TDCI XS,
Post #1054129 8th Dec 2024 7:41am
TexasRover
Why exactly the double Cardon joint? When I had a D2 they were a known (catastrophic) failure point.
Post #1054132 8th Dec 2024 10:07am
Disco2 DC joints are only a significant weakness on V8 versions and the general understanding is that this is due to the proximity of the exhaust which accelerates dessication of the grease in the joint. Disco2 DC joints also lack grease nipples as standard which causes a further problem. That having been said, mileages well over 150k are normal on TD5 vehicles without prop shaft problems.
If the failed prop shaft in this thread is a Gwyn Lewis HD shaft (and I am really not sure if it is or not but it doesn't look quite as substantial as my GL DC prop), the joint is substantially larger and stronger than that of a Disco2, and I would be extremely surprised if the prop shaft initiated the destruction - it is I think more likely that the prop shaft was compromised by something else.
We don't know from what has been said so far what has actually failed on the joint, it looks to me as though the spigot on the long side which fits in the centre of the spherical bearing has sheared off. The spigot is under very little load and it is hard to understand what would lead it to fail, unless there was a metallurgical defect (which should be apparent in the fracture face), or a solid object such as a stone became lodged in the joint, or something (like a gearbox) fell on the joint ,or the alignment of the joint became so disrupted ,for examle.by the transmission moving somewhere it shouldn't, that the limit of articulation was exceeded. It is.evident that the giant hole in the gearbox was caused by the prop shaft but from the photos it isn't possible to say which came first.
Whatever the cause is is an extremely disturbing, extensive and expensive failure. The destruction is shocking.
Post #1054137 8th Dec 2024 11:20am
DSC-off
Indeed. Someone considered this scenario to be enough of a possibility and designed a bracket to do exactly that.
Quite a shocking result. A prompt to check the transmission mounts and replace any worn ones ASAP!
Post #1054142 8th Dec 2024 12:14pm
DSC-off
The bracket on the crossmember has actually done a good job.
The 'bent bracket' construction, with no stiffening or reinforcement features, was able to deform on impact, then cradle and support the gearbox without totally collapsing.
Mystery function resolved. Thumbs Up
Post #1054144 8th Dec 2024 12:23pm
jbcollier
Yes, it is a GL shaft. I'm also back to the centre joint giving out first as the mounts were also fresh and there was absolutely no clunking or lash present, and mounts have failed in other vehicles without such destruction. That does not mean, however, that GL shafts are a problem. We don't know why the centre joint failed. As Mr BW has said, there could have been a mechanical reason for the failure (rock, etc).
I haven't shown you everything. It also shattered the housing between the gearbox and the transfer case. That is what allowed it to drop down, pivoting on the one-piece, LOF connector shaft. I'm thinking that it might have gotten REALLY interesting if I had the original two piece shaft.
I'm not going to replace the GL shaft for reasons other than once-bitten-twice-shy. The GL shaft is a heavy lump, easily twice the weight of the modified D2 shaft. I do some off-road but nothing too extreme. It is mainly a hauler* so no need for the extra articulation and weight.
* there are actually very few vehicles that can carry two canoes, four people and all their gear. It is also, after a few mods, the very best 25-below and blizzard-ing vehicle on the planet.
Post #1054151 8th Dec 2024 2:46pm
I thought it looked as though the transfer box and MT82 had separated.
I.assume that both axles roll freely still? I was wondering what would happened if either the transfer box or MT82 locked solid at speed, could the drive line shock wrench the DC joints apart?
Post #1054156 8th Dec 2024 3:49pm
