![]() | Home > Puma (Tdci) > Problem between 2000rpm and 3000rmp |
Black smoke is a sign of over fuelling, is there any air input restriction at all? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 40 ![]() ![]() ![]() |
Or perhaps egr related.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17853 ![]() ![]() ![]() |
Can you describe the "strange noise"? Is it a whistle, shriek, or farty noise by any chance?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Check your turbo, exhaust manifold gaskets would be my suggestion.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Vicious cycle. Overfuelling-clogged turbo vanes Puma 110" SW
rusty81 Member Since: 27 Oct 2024 Location: GAND Posts: 5 ![]() ![]() ![]() |
It's more like a sputtering.
I replaced the turbo last year with a replacement turbo. There's no play in the turbine. I think it could be the wastegate. Or the injectors. Landrover series3 109 1980-1999 Landrover 110 td 1988- 2010 Landrover defender td51999 -... Landrover defender tdci 24 2010-... |
Was it a new Turbo assembly including a new Electronic Actuator as well? _\Hennessey|Venom| F5/___
It was a compleet refurbished one with accurator from autodoc. Landrover series3 109 1980-1999
Try dripping some light oil on the turbo actuator pivots, and see if that makes any difference at all and if the vanes are free.
Presumably the Turbo model number and all serial numbers match the original? _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I'd be concerned if it was the waste gate!
There isn't one on a Puma. |
