Home > Puma (Tdci) > Stainless Bolts etc
Page 1 of 3 123>
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Stainless Bolts etc
Iv just bought stainless steel bolts and screws from Paddocs to cover pretty much the whole truck, but i was wondering if i should put any sort of anti corrosion stuff on them before putting them on ?
Any suggestions ?
Thanks
Post #105245 7th Dec 2011 9:29am
T1G UP
Re: Stainless Bolts etc
Any suggestions ?
Thanks
got a link? and yes, copperslip at least. i do believe there are some special pastes for cross metalic corrosion
Post #105251 7th Dec 2011 9:49am
leeds
Duralac
Que K9F Razz
The better companies who supply stainless bolts etc for 4x4 supply a sachet/small tube of anti corrosion paste from Wurth
Brendan
PS Information available HERE
Post #105255 7th Dec 2011 9:58am
Lorryman100
Duralac Chromate Paste
Glasgow stockist: http://www.duncanyacht.co.uk/search.asp
But any yacht chandlers will stock it.
Post #105256 7th Dec 2011 10:00am
scottish110
T1G UP wrote:
Any suggestions ?
Thanks
http://www.paddockspares.com/parts-and-acc...xings.html
Post #105259 7th Dec 2011 10:08am
Grockle
I covered the threads with vasaline when fitting ours. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #105267 7th Dec 2011 10:53am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
On steel built cars you can use copperslip, but dont do that on our aluminium shells - building batteries does not solve problems! Go for TefGel, Weicon Anti Seize or anything related instead. BTW what does MOT tell you about stainless bolts? our German TÜV might be very unhappy /w stainless bolts on chassis carrying parts. Never forget: cars have owner, Landrover have field service personnel.
Post #105289 7th Dec 2011 12:31pm
Grockle
same here, you shouldn't use SS fastners on any stress or load bearing fastenings 2.4 90 XS
Post #105298 7th Dec 2011 1:19pm
Zagato
Stainless steel DOES rust and is not very strong, it's not necessary to use them. Use proper fasteners and cover with usual suspect potions if worried about rust!
Post #105349 7th Dec 2011 5:23pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
ah, if only our friends at Land Rover would use proper fasteners in the first place...
Go retro and use sheradized fasteners...many of them were still fair on my Series 1 when I bought it - those were the days Thumbs Up 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #105381 7th Dec 2011 7:02pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
not strictly true Zag - you can buy different grades of stainless (as you'll know from your boating exploits) and when specifying stainless bolts you can specify ones which are actually stronger than 'ordinary' steel bolts - as always it's worth checking the application and buying accordingly.
Post #105413 7th Dec 2011 8:33pm
Zagato
I stand corrected Thumbs Up
Post #105418 7th Dec 2011 8:46pm
scottish110
I'm confused now ! Zegato, are you suggesting that I do not use the stainless bolts fro
Paddocks to replace the rusted ones ???
Post #105431 7th Dec 2011 9:22pm
leeds
S110 there is a large number of metals referred to as stainless steel. These are resistant to corrosion in different environments.
The two most common stainless bolts are referred to as A2 and A4
A2 is nominally resistant to corrosion in fresh water
A4 is nominally resistant to corrosion in salt water and chemicals
Common stainless bolts are referred to as A2-70
A2 meaning resistant to rusting in fresh water the 70 refers to strength and is 700 N/mm2
A standard mild steel bolt is marked 8.8. The first 8 refers to a strength of 800 N/mm2 whereas the .8 refers to stress at permanent set being 80% so ).8 x 800 = 640 N/mm2
Real High Tensile bolts are rated 12.9 12 refers to strength of 12 N/mm2 whereas the .9 refers to stress at permanent set being 90% or 1,080 N/mm2
That is the general reason why stainless bolts in high stress situations are not recommended.
HTH
Brendan
Post #105434 7th Dec 2011 9:42pm
Zagato
Brendan knows the theory I only know that many advise not to use SS bolts on resto's/rebuilds due to strength/cost and they do rust anyway. Sheradised stuff is costly so most use the standard zinc coated fasteners, I bought ALL the correct size UNF fasteners for my rebuild for £110 Shocked and then you could use sheradised bolts if you want to for authenticity (although LR used a mix of bolts not just sheradised!) such as bumper bolts etc as they look nicer Thumbs Up
Post #105499 8th Dec 2011 11:30am
Page 1 of 3 123>
