Home > Td5 > injectors all high impedance
alexatnd
ok so given that im fitting a new. ACR cylinder head and cam to my TD5 i thought I'd. go the whole hog and get the injectors tested/refurbished, so sent them off to United Diesel Fuel Injection Services Ltd to be checked out.
Injectors were deliverd next day and. then i got a phone call that afternoon saying all 5 injectors were showing high impedance andn failed at 1st hurdle. As they cant get the electrocal parts, not much they could do with them.
Basically. ws told that while they would work, highly likely to cause problems when running/warm with fault codes appearing.
Net result is I'm waiting delivery of a set of reconditioned injectors costing slightly more that price of. refurbing the ones ive got.
Now wodering what could have caused them to go phut!.
Gertie had been sitting for a month or so b4 i put a newly charged battery in to drive the 10 ft to put nose in my garage. Problem was when i turned the ignition key, was treated to loud relay clicking noises from area of fusebox behind. gear lever and the EMS and glowplug lights were flickering at a high rate.
Switched off, gave all the relays a re-seat , tried again and she started almost 1st time.
Basically nose in garage, injectors and head off, left injectors sitting on top of chest freezer near doorway till i sent them off a couole of days later.
Not aware of any. injector fault codes ... gues too late to look now.
So question is what can i test b4 i connect up the unexpected expensive. injectors as i'd grumble a bit if these ones go phut! as well
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1052618 23rd Nov 2024 1:00pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Electrical part of injector is just a coil. Mechanical parameters of the coil are fixed (diameter, length, diameter of used wire and number of turns), so you can easily measure the reasistance of the coil.
When operated, coils in injectors are driven by ECU - pulsed voltage 85V with approx. 25A of current. Measuring of the resistance cannot with some multimeter cannot damage the injectors.
TD5 engine ECU is tightly controlling the current through injectors, so if you had not any problems with engine running of fault codes, I would check the injectors by someone else. It is wery unussual to have all injectors broken. I can imegine it only with broken ECU - burnt through in multiple places, as it has switches for both positive and negative wire to injectors. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1052979 26th Nov 2024 10:37am
alexatnd
Many thanks for the reply. yeah, bit twitchy about installing. new ( refurbed) injedtors if theres a chance of them getting trashed.
Suppose 1st thing is to plug in my LynxEvo to see if there are any errors. guess can do that even if the injectors arent connected just to see if there are any existing error codes
Have found a company that will check out the ECU for me ... obviously at a price ...
Post #1052996 26th Nov 2024 12:27pm
MadTom
You can connect injectors (old ones) without mounting them in the engine head, and then test them through diagnostics - ECU can click them. Do it more than once for all injectors and look for any faults in ECU. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1053086 27th Nov 2024 10:13am
TexasRover
Yes I would take the feedback from this specialist with a grain of salt. Possibly they misread the specs because it would be very unlikely that ALL 5 injectors removed from a running engine would all be faulty, especially since there is not much to the electrical parts of an injector.
Note that Td5 injectors are not like modern Common Rail injectors, maybe the expert got confused. Where on common rail the solenoid opens to allow flow, on Td5 injectors the solenoids stop (disrupts) the pressure and fuel outflow once enough fuel has passed by bleeding off the pressure to the return line. The pressure does not come from a common rail pump but instead is build up within the injector by the camshaft, same system as used on large industrial diesel engines.
Post #1053088 27th Nov 2024 10:33am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I was talking to an injector specialist who seemed pretty clued up on Td5 injectors and said the coil has a really tight tolerance and they cannot get them new anymore, so maybe yours just unfortunately fell slightly outside this limit, Better the change them, rather than recon them just to fail down the line.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1053091 27th Nov 2024 11:14am
alexatnd
What a good idea. This is tail end of a long battle.
Originally asked local garage to change injector seals on this engine ( never done it before) ... and all 6 rocker arm bolts sheared .... Had a spare td5 10p engine in garage ( as you do Smile) so they took the head, injectors and all off that and fitted it
Then had head gasket losing cooland issues so took original head to be skimmed and tested by machine shop in Castleford and fitted that with the (spare) set of injectors given the ECU was reprogrammed for them.
So ive got the original injectors on the shelf. As you suggested, I'll connect them up and see what LynxEvo thinks of them Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #1053094 27th Nov 2024 12:06pm
alexatnd
Will
Yeah, so they had a set of reconditioned injectors that i've bought ... as per other reply on this thread.Will test with old injectors 1st to check ECU
Was talking to someone from Alive Tuning yesterday who said that theyve never found anyone who can recondition td5 injectors successfuly and my best bet would be to just try and find a working set.
Post #1053096 27th Nov 2024 12:12pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Td5 injectors
We went through 2 sets of reconditioned injectors not operating correctly before getting a set that were supplied via Landrover (from Britcar).
Chris
Post #1053100 27th Nov 2024 12:56pm
alexatnd
eek! hope not, the replacement ones i've jsut bought are expensive enough
Post #1053104 27th Nov 2024 2:07pm
MadTom
Tight tolerances of coil parameters? Do you know details, or it is just a way, how to tell custommer, that they don't know, what to do? During my attemps to repair TD5 ECUs I made full schematics ot the ECU itself and some tabletop tester to run the ECU outside of the car. Power switches (TOP and BOTTOM switch) are simple, sensing circuits around them, to controll the current through injectors not. I was testing ECU first with set of used injectors, but it was quite noisy and smells from diesel. So I made some coil to simulate coils in injectors to make ECU happy. It was like 10% around coil parameter of injectors, and ECU is happy now. So no strict parameter.
Reconditioning injectors is all about the high pressure parts - pump, nozzle and the rest between then. I have seen some bad after attemp to clean then, and some good remanufactured with factory new parts. I'm not sure, that these parts are still possible to buy.
For testing, there is no need to set up the injector codes in ECU. TD5 will run with any codes, probably just not as smooth as possible. For longer use, it is necessary ut use right ECU/software in ECU with right codes. With Nanocom it is possible to write the injector codes with running engine and see/hear/feel the change. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1053169 28th Nov 2024 7:43am
alexatnd
So do i have to unplug the fuel pump relay as well? or just connect injectors to the loom ?
Am I not going to have diesel spraying when i turn ignition on ? Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #1053746 3rd Dec 2024 5:25pm
TexasRover
The electric pump is just to feed and provide some positive pressure. The injection pressure comes from the cam that acts on the injector plunger. Without a cam there is no pressure. Also the solenoid releases the injection pressure
Post #1053750 3rd Dec 2024 6:05pm
derbywill
Yes take the fuel pump relay out, or the fuel pump will run in the tank and fill the bores up with diesel.
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1053777 4th Dec 2024 8:38am
alexatnd
The joys of finding what relays do what in a defender. Gertie is a 1999 td5 110
piccies attached, 2 relays under drivers. seat, few behind gearstick, some people suggested might be the green one ... the again local land rover parts supplier said its the yellow relay under the seat ....
.... and its the green one. Unplugging the yellow one under the seat stops EMS,glowplug and charging light from apearing Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #1053818 4th Dec 2024 6:09pm
