Home > Faults & Fixes (L663) > Intermittent starting failure
Page 2 of 3 <123>
DrRob
What issues have you based your rejection on? I’ve got until end Jan to do same if they don’t fix the intermittent starting issue after one attempt.
Also, did yours start on second press of the button? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1053262 28th Nov 2024 8:46pm
Flinders
I’m the one on the Facebook group that has the rolling backwards defender. You shared info on consumer info for faulty vehicles. Didn’t think it would get to this but after 2 repair attempts and more damage to the car I’m rejecting. Still waiting for JLR decision as I’ve requested an AVC (assisted vehicle change).
It also has squealing ventilation fans and the EPB release is very noisy. Quite a few little electric gremlins but not sure if this is just PIVI pro.
It did start when I pressed start again and I just put it down to one of the gremlins the vehicle has.
First time ever I’ve bought a brand new car so total disappointment for me Rolling Eyes 5th Land Rover and the previous second hand ones has been better! MY25.5 Defender 90 D350 X Dynamic HSE - Maximus
MY25 Defender 90 D350 X Dynamic HSE - Boris - REJECTED Sad
MY18 Discovery 5 3.0ltr TD6 HSE Lux - Derek
Post #1053272 28th Nov 2024 10:23pm
Flinders
Deleted duplicate post……. MY25.5 Defender 90 D350 X Dynamic HSE - Maximus
Post #1053273 28th Nov 2024 10:23pm
DrRob
Ah thought so 👍 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1053274 28th Nov 2024 10:24pm
Eric Caterpillar
Didn't want to create a new thread, as I have observed a similar issue on a number of occasions, so I'll post my points here.
My car with under 1000 miles did not start its engine a few times, the dashboard lit up and pivi initiated all the usual welcome screens, but the car didn't start. Had to turn the ignition off and try again and it worked on a second attempt. Didn't pay much attention until I saw the OP reporting something possibly similar.
I then noticed that if I push and hold the start button instead of just pressing it the engine always starts. The manual says that this is the procedure after refuelling (?).
Subsequently, I purchased a battery tester and a trickle charger, admittedly, I don't how to perform a 100% accurate test, so just went ahead with a default:
500CCA
Cranking Test
Charging Test
And finally connected car's battery to the noco charger, it states the battery current status was under 50%.
Is there anything of a concern or should I be doing something differently? Admittedly, not entirely sure how to run the battery diagnostics.
Is that the state of affairs with these new Defenders that the battery is not up to the task without maintenance?
Post #1053718 3rd Dec 2024 11:15am
Alicat
Afternoon all
I no longer own an L663 Defender, but the starting issue was affecting several owners in 2021.
Mine displayed this issue. It would power up and everything was normal, but when you pressed the Start button nothing happened. However, it would always start on the third push of the button.
It happened randomly. It would be fine for weeks, then there would be a few days it wouldn't start until the third attempt.
Post #1053741 3rd Dec 2024 4:22pm
Gareth
Interesting that my Defender received an over the air update yesterday taking it to version 4.2.1 and the notes say it’s mainly to do with rectification of a fail to start scenario following cranking of the engine, and better management of the battery management system (BMS). 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1053754 3rd Dec 2024 6:45pm
DrRob
That is very interesting 👍🙏 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1053760 3rd Dec 2024 7:25pm
Eric Caterpillar
I noticed the new update was available today, after two weeks from the first reported download. Wonder if it's because I trickle charged the battery and the car can now perform the update?
Indeed, the wording on the software update seems to be addressing the very engine cranking issue.
Post #1053855 4th Dec 2024 11:52pm
DrRob
Should be getting mine back soon. Been there 4 weeks Shocked
Sat for 2 weeks waiting for workshop slot Rolling Eyes MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1053952 5th Dec 2024 10:50pm
Flinders
Hope yours is resolved Rob. Mine did it again today and thankfully my husband was in the car to witness it so I knew it wasn’t anything I’d done! It also did the software update earlier this week so that’s not resolved the issue.
It is being collected on Wednesday so it will be the dealers problem and probably to poor unfortunate person who buys it as a used vehicle with none of the faults resolved Neutral MY25.5 Defender 90 D350 X Dynamic HSE - Maximus
Post #1054176 8th Dec 2024 7:08pm
DrRob
Thanks for update. If it’s not resolved then I will reject it within the 6 month window Neutral MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1054194 8th Dec 2024 9:11pm
DrRob
Collection day........time will tell Whistle Laughing MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1054431 11th Dec 2024 1:56pm
DrRob
So far so good. I am pressing the pedal and button firmly and maintaining pressure until it fires so that I have a baseline Thumbs Up
I did update to 4.2.1 on collection MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1055108 19th Dec 2024 1:45pm
Eric Caterpillar
I did charge up the battery with a trickle charger and have been maintaining a similar routine, brake firmly pressed and push and hold the start button for 3 seconds.
Pivi pro update to the latest version, but only after topping up the battery.
So far so good.
Post #1055115 19th Dec 2024 3:06pm
Page 2 of 3 <123>
