Home > General & Technical (L663) > Flappy paddles
Page 2 of 3 <123>
David007
Thanks for the update, hope you manage to get this working as I’d quite like to do this as well👍
Post #1039993 15th Jul 2024 10:16am
northeye
Japan
Hello, long time no see.
Eventually, I contacted the GAP team because the CCF relearning operation on the TCM (Transmission Control Module) always failed.
Since I believed that the TCM was crucial in this case and many times tried and error.
They provided me with a special build of the G4 firmware, which can successfully perform CCF relearn, and the paddle shifters now work properly.
Yes, the IIDTool G4 can now enable flappy paddle shifters.
We should wait for public release of the new firmware though.
I’m so grateful to the GAP team, thanks pat.
Post #1052212 19th Nov 2024 5:33pm
Nashvegas
United States
This is very good news as it's one of the things I intend to do !
Post #1053290 29th Nov 2024 4:20am
spacegit
United States
New member here.
2024 P500 V8 SE owner
I can confirm this works using the GAP IIDTool G4 after I obtained the the beta F/W from Patrick.
You need build 171 for it to work.
As I already had a heated steering wheel as standard, I didn't need to swap out the clock spring or the right hand steering wheel switch pack. If you don't have a heated wheel, these parts will also be required and will add significantly to the cost.
Note that after installing everything, until you actually update the CCF to enable the paddles and perform the TCM relearn you will get a diagnostic fault code set for the right hand steering wheel switch pack, that indicates an internal fault with the unit. I think this happens because this switch pack is sensing the presence of the paddles and starts to send CAN messages accordingly, which does not match with the car's configuration. Once everything is updated this error goes away. A further PIVI reboot is needed for the menu options for the shift paddles to appear.
These are the parts I needed
1) Left paddle - LR139904 - $121.28
2) right paddle - LR139905 - $121.28
3) Alcantara Steering wheel - LR183013 - $711
4) Steering wheel wiring loom - LR142723 - $162.08
5) Paddle mounting machine screws (4x) - LR140025 - $1.18 each
These parts were all ordered from Uk suppliers and shipped to the US. Most of this stuff seems
to be on backorder here with no ETA. These parts all arrived from the UK within a week or so.
One final note - my car has the electrically adjustable steering column and due to having ZERO slack in the loom to the column adjustment control on the lower shroud, it made getting the thing off without causing damage a huge pain in the arse.
Post #1053695 2nd Dec 2024 11:43pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You can remove the steering wheel without removing the cowls, you need a hex tool with a round end like the one in the photo below. Turn the steering wheel until one of the air bag release holes is at the top, use one of the tools (round end) to inset it into the hole and wiggle it about until the air bag pops off the first clip, then turn the wheel 180 degrees and do the second one. I worked this out after struggling to remove the cowls as I have electrically adjustable steering also. You may want to disconnect the battery while sticking your tool in to be on the safe side and plus it's easy to sound the horn. I can pop the airbag off in less than a minute now Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1053698 3rd Dec 2024 1:05am
northeye
Japan
Yes, this video was helpful for me.
?si=UdAug46RF15nTbje
Post #1053699 3rd Dec 2024 1:14am
spacegit
United States
Have to admit I tried it that way to start with and I struggled to get it to engage the sprung retainer.
I had seen the video too. I guess I'm just too ham fisted
So I bit the bullet and took the shroud off anyway in the end to give me a bit more space to work with.
i was able to do it without damaging or scratching anything.
And yes, once you get the right technique, its straightforward. And then once you see inside one can appreciate exactly how its constructed and how best to unlatch it, and that really helps to understand how to optimize the technique.
Once i got past that hurdle the rest of the job was very simple.
Post #1053700 3rd Dec 2024 1:17am
David007
What a great post, thanks very much "spacegit" probably all the information needed now to carry this out Thumbs Up
spacegit wrote:
New member here.
Post #1053703 3rd Dec 2024 7:40am
Colin68
I have fitted new steering wheel and paddles.
I have updated the ccf files but it shows failure when i perform the TCM learning. Any ideas?
Post #1060842 18th Feb 2025 12:52pm
northeye
Japan
You need beta firmware of G4 at least build 171, ask Patrick.
Post #1060845 18th Feb 2025 1:11pm
Colin68
After emailing Patrick I downloaded Beta 195 and it now works. I was able do the learning on TCM.
Post #1061030 21st Feb 2025 1:31pm
isugoo
United States
Anyone has part# for leather version of V8 steering wheel?
I personally can't stand Alcantara (well, after 3 months, you know what I mean).
If anyone has a heated leather version steering wheel part#, please share with me.
Thanks!!
Post #1062339 8th Mar 2025 3:37am
isugoo
United States
I just ordered new steering wheel. How can I email Patrick for new firmware? (email address available or just use contact us form from their website)
Post #1062668 12th Mar 2025 5:42am
isugoo
United States
I ordered steering wheel based on your part # yesterday.
But today my dealer called me that steering wheel part # LR183013 is non-heated. Even though I dont really trust part department people, I cancelled my order as it's not refundable.
If you dont mind, can you please let me know LR183013 is ancantera/heated/paddle shifter wheel?
Thanks!
spacegit wrote:
New member here.
Post #1062764 13th Mar 2025 4:58am
Hairy Dan
I fitted a heated Alcantara wheel to mine and the part number was LR156931 Cheers Ian
Kielder 4x4 Safari
Post #1062782 13th Mar 2025 10:33am
Page 2 of 3 <123>
