![]() | Home > Puma (Tdci) > Front/Rear wheel bearing nut conversion |
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 40 ![]() ![]() ![]() |
Hello, I believe you are correct and that it is foreign materials that kills the bearings. Modern bearings of a decent quality will wear very slowly and outlast the seals. This is also one of the reasons for my question, since I do not find it necessary to adjust the bearings during their life cycle.
What a mess that mechanic made. All the more reasons to do things yourself, although I like to think that most mechanics have some professional integrity. Maybe I am naive - which is btw. the finest thing you can be - but I was shocked by your photo. I sometimes doubt myself and wonder if I should have just let the Land Rover specialist carry out the work, but I really want to do everything myself, so I am 100% sure no shortcuts are taken and everything is pampered like an infant. My rear driven members were also worn completely out a 195000 km. All the bolts came out with ease, but I did soak them with penetrating fluid and heated them with a flame before using force. In my experience you are hard pressed to snap a bolt that way. I hope you get more miles out of your bearings this time. |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 140 ![]() ![]() ![]() |
It was a mess indeed. Sorted it (almost yesterday). The reason for the play was most likely that the one nut was not torqued to 210Nm, I could almost remove it with finger force once the staking was chiseled out. The 210Nm is meant to compress the spacer ever so slightly to get the correct end float. With a much lower torque these bearings probably had play from the start.
To counter the low torque he instead had gone bananas with the staking, cracking the one nut partly and also deforming the stub axle. This had consequences as I noticed when I prepared the drive axle to be inserted. I noticed there was scratch marks all over the length of it and, of course in particular, where the seal lip sits. I couldn't figure out where these came from but when I inserted the axle I realized there was a sharp edge sticking in from the crushed stub axle and if one was not careful it would scratch the axle. Therefor I am likely to do this job again in the near future as I guess also the new seal will fail. Apparently he had also damaged one of the bolts for the caliper and tried to use another bolt, but not with fine threads as they are, but normal once. Obviously he didn't get far but left it at that. Fortunately I managed to insert a correct bolt from the other side and with a lot of patience and half a can of WD40 I got it through. |
What a nightmare. Good you are sorting it now
