![]() | Home > Wheels & Tyres (L663) > 18 inch rub caliper on D200 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2769 ![]() ![]() |
Sounds like a problem with the wheels. The standard 18” steel wheels fit fine with plenty of clearance.
Modder Member Since: 29 Nov 2024 Location: Wuustwezel Posts: 17 ![]() ![]() |
Does someone has a picture of the normal clearance with 18 inch wheels?
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 72 ![]() ![]() |
I don't know if it's good to see.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
If the caliper is rubbing the rear face of the steel wheels couldn't you fit some wheel spacers to move it further out?
The offset you have is lower than the stock wheels so that seems to be your issue. I bought some wheel spacers a few months back to use with my alloys but I've since taken them off. 30mm Terrafirma ones, they were only £145 to buy. |
Thanks that gives a good idee like its close but still some room |
Will take a look at spacers, but don't want to go to wide as they are illegal in Belgium. So i dont want it to stand out too much. |
