Home > Off Topic > A visit from Storm Bert
Page 2 of 2 <12
Zed
I just tried to go to a local town but it’s completely cut off by flooding. As per usual at least one person tried and failed leaving their Mercedes stranded in the water. WARNING.
Post #1052860 25th Nov 2024 12:02pm
It's curious how the more posh and expensive the car, the more stupid the driver, or so it seems. Why do so many Mercs and Beemers end up in floods!
Post #1052863 25th Nov 2024 12:22pm
Zed
Stupidity? Entitlement? Probably a combination of both. A few winters back I had to recover a neighbour’s Porsche Cayenne turbo from his snowy field. Like many 4x4 owners he went in for a play. Nothing wrong with that, we’ve all done it. However he was outraged that his £150k car got stuck and had to be unceremoniously towed out by “an old Defender”. I tried to explain that 22” road tyres probably weren’t the best option for knee deep snow but he still wouldn’t have it. He didn’t even thank me afterwards. Looking back I wish I had left him stranded. WARNING.
Post #1052869 25th Nov 2024 1:40pm
White BMW I saw stranded today, nearly new, the second this year. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1052871 25th Nov 2024 1:43pm
spudfan
Ireland
I do carry extra water/washer fluid mixture. Things get really bad when the rain stops and traffic throws up road crud that just cakes the windscreen. You get through a lot of water on a journey like that! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1052907 25th Nov 2024 5:29pm
Tell me about it!
I really need to figure out how to fit a much larger reservoir to the Defender. The standard one is ridiculously small by modern standards.
Post #1052909 25th Nov 2024 5:33pm
Any 3D printing possibilities? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1052918 25th Nov 2024 6:27pm
Not really, it would be easier to fabricate one, but the real problem is simply a lack of space.
Post #1052932 25th Nov 2024 7:43pm
That’s true, and the fixing points are at some bizarre angles as well.
I guess you could have external dimensions taken by some expanding foam in plastic bag, but getting it out might be a reason not to do that, or modelling clay that could be adjusted.
I’d imagine if there was a bigger version it would sell, it’s a bit of a pain having to top it up often.
Also if the level keeps going down, consider replacing the cap I found mine leaked from the cap when it shouldn’t have and was losing washer fluid because of it.
So that’s why plenty was disappearing faster than it was being used. Laughing ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1052933 25th Nov 2024 7:54pm
Zed
On my quest to rid the engine bay of plastic I looked at getting an aluminium reservoir made up. Obviously can be done even with the odd shape but would be quite spendy. With 3D scanning it could be made bigger but I doubt it would be cost effective for many. Saying that if anyone fancies a go they can put me down for one! WARNING.
Post #1052936 25th Nov 2024 8:28pm
Retroanaconda
Fitting double washer jets saves a huge amount of fluid as it then only needs a short push of the switch to get the screen nicely covered, rather than the “hold down the switch long enough for the wind to blow the water around sufficiently to cover the screen” method that the factory single jet requires.
Post #1052947 25th Nov 2024 10:00pm
Page 2 of 2 <12
