Home > In Car Electronics > Headlight level motor fuse 13
xrodney
 2015 Defender 110 Puma 2.2 USW Santorini Black
Hi everyone
My headlight level motor seems to be stuck and there is a constant noise when the lights are on. I removed the fuse until I get it repaired but there is another symbol that looks like cruise control
Can someone confirm that by removing that fuse nothing else is afffected?
Thanks
Post #1052575 23rd Nov 2024 5:25am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Is the other symbol the one for the in instrument binnacle illumination?
You should add the details of your vehicle to your profile so that folk can see the year and model of your Defender.
Jim
Post #1052576 23rd Nov 2024 5:49am
xrodney
It is a 2015 2.2 puma. Instrument binnacle lights up
Post #1052577 23rd Nov 2024 5:55am
landy andy
The symbol looks more like a rev counter as has the slope under it.
Or possibly for the unit which increases revs for PTO (when/if fitted)
Or tacho (when/if fitted).
Post #1052585 23rd Nov 2024 8:03am
xrodney
Rev coumter works too
Must be another accessory Defender 110 Utility Station Wagon 2015 2.2 Puma
Post #1052591 23rd Nov 2024 8:54am
landy andy
As long as everything works I’m sure it will be fine. Just carry the fuse in case.
Alternatively disconnect the levelling motor.
My headlight levelling motor is the opposite to yours. After a bird strike it now longer works. Big Cry
Post #1052596 23rd Nov 2024 9:42am
Martin
Site Admin
None of your dash switches will be illuminated with F13 removed.
The icon means dash/gauges illumination, however the icon is misleading, as the cluster is actually illuminated by the sidelight feed it receives from F11.
https://www.lrworkshop.com/wiring-diagram/...lumination  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1052615 23rd Nov 2024 11:28am
xrodney
I still have illumination in switches Defender 110 Utility Station Wagon 2015 2.2 Puma
Post #1052637 23rd Nov 2024 1:05pm
xrodney
Solved. Yes Martin there was no illumination on the centre switches.
Took out the headlight, loosed the bolts and all is working Defender 110 Utility Station Wagon 2015 2.2 Puma
Post #1052664 23rd Nov 2024 4:33pm
