![]() | Home > Maintenance & Modifications > Defender TD5 6HP Auto Conversion |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8371 ![]() ![]() ![]() |
6hp into a defender yes done it.
M57, understood, that's me out. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
Haha just not right now. I like my Td5 its 280hp, easy to work on and 550nm+ of torque so no slouch.
Just getting a bit tired of the R380, eventually need a new uprated box, clutch will need doing in maybe 30k as well. Modernish auto would be nice and paves the way for an M57 in the future. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2380 ![]() ![]() ![]() |
I know MW do a TD5 to 8hp but I don't think there's one to 6hp. At least that I've read of !
But I also have an M57 so that's me out too 😁 Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
I believe they use the same bolt patterns, tbf not overly troubled what.
Dont discount yourselves id like to see the interior for some inspo ![]() |
![]() Click image to enlarge The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Oo thats tidy! That the ashcroft center?
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Sell a kidney and fit a Quaife sequential 6 speed . WARNING.
This post may contain sarcasm. |
Tbf both probably end up similar prices!
Actually joking aside, you’re probably right. Plus you would have to spend quite a bit more to make an m57 auto quicker than a tuned TD5 with sequential. It’s a no brainer, get that kidney on eBay! WARNING.
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 350 ![]() ![]() ![]() |
What is that blue surround on the key Barrel Mo? 4.0 V8 Defender 90 My Instagram |
Xeng column lock. Block of cncd stainless around the key barrel. For extra security
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
i frequently think of doing an auto conversion to mine, but don't want to use a D2 auto box. i would consider an 8hp conversion myself
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 220 ![]() |
I think the biggest issue is going to be interfacing with the ZF Transmission Controller - the aftermarket TCUs require inputs from the engine ECU on throttle opening / RPM / Load / speed etc in order to be able to determine the shift points, lockup etc - these normally come via CANBUS direct from the engine ECU.
As far as I know, the TD5 ECU doesn't speak 'normal' CANBUS, so you are going to have to hook these up somehow to get these into the TCU.. |
Perhaps it would be easier to just remove the TD5 from the equation and fit an M57 instead ?
![]() ![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
