Home > Technical > Defender front door latch: what does this arm do?
Dr Phibes
Australia
Hi All
I just replaced my RHS front door latch, and realised that if the arm in the red circle below is pulled up, it addresses a previous annoyance: that I need to hold the button in on the door handle when closing from the outside. As you can see in the picture I have temporarily pulled it up with wire but can’t see any fixture that I could connect to permanently if using a cable tie etc.
My LHS front door is the same.
What’s the function of this? Is it supposed to be pulled up permanently?
Post #1051960 17th Nov 2024 1:36am
L110CDL
I've not come across this problem before, is it a 300 Tdi door, if so would it help you if i was to take my door card of and have a look for you, if so i can do it this weekend ? Very Happy Clayton.
Keeper.
Post #1052343 20th Nov 2024 9:26pm
Dr Phibes
Australia
Thanks but it’s a TD5. I am going to replace all of my door actuators with eBay ones, and bypass the AS10 being removed. I don’t think the position of that arm will matter when the door is closed.
Post #1052345 20th Nov 2024 9:34pm
landy andy
That is the lock isn’t it? Goes up to the door button inside.
Post #1052346 20th Nov 2024 9:36pm
Dr Phibes
Australia
No. The rod is one I added. I thought at first that internally it connects to the same mechanism as the door opening latch, but the door stays closed with it up.
Post #1052348 20th Nov 2024 9:40pm
landy andy
Post #1052349 20th Nov 2024 9:43pm
Dr Phibes
Australia
Best guess is that it is for a different variant, normally disconnected in td5 defender.
Post #1052355 20th Nov 2024 9:59pm
rustandoil
Does this help in any way...?
2005 TD5
Post #1052381 21st Nov 2024 8:57am
That part I believe is for the door “pin” in the upper door card, down is locked, up is unlocked.
If it’s mechanism somewhere is sticking or blocking then you could have the effect of the door preferring to stay open or locked.
Applying some silicone lube on all of the mechanisms is well worth doing, especially if it hasn’t been done in many years, it’s one of those jobs worth doing once in a blue moon like the windscreen wiper rack.
If you have central locking, elec windows etc it will make a lot of difference to everything much smoother and lighter work for CL actuators and window motors etc, smoother, and quieter. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1052392 21st Nov 2024 11:11am
