Home > Puma (Tdci) > Short journeys in Puma 2.2
lightning
My day consists of journeys generally under five miles between customers, often less maybe a couple of miles.
l do get the odd longer journeys over five miles but rarely over around 40mph.
Time spent with each customer is usually under an hour which means the engine is usually still warm when l return to the vehicle.
So it's not just a short journey and then not used again, the vehicle is in use all day.
Will the EGR in the 2.2 cope with this. And if not, what would l have to do to keep the engine happy?
Post #1052132 18th Nov 2024 10:12pm
90 Dreamer
Pretty much no modern diesel ‘likes’ that type of use…..a decent ‘faster’ run of 10-15miles will help keep things clean know and again…
Post #1052133 18th Nov 2024 10:15pm
The DPF is more of a concern _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1052136 18th Nov 2024 10:42pm
Chicken Drumstick
Re: Short journeys in Puma 2.2
I imaging it would be perfectly fine. Same engine used in the Ford Transit and Ford Ranger, 2 of the best selling vehicles in the UK I'd have thought. There must be 1000's of these being used daily in the way you describe.
Which is probably true for most modern diesel in the past 10-20 years or so. I know forum people like to moan that no diesel can manage short journeys, but the reality is, I suspect that most of the diesel do this kind of thing most of the time and are no problem for the very vast majority of people.
Post #1052142 18th Nov 2024 11:22pm
Ianh
So,
How many years have you been driving like this?
How many miles a year do you do?
Do you do any longer regular high speed journeys as part of this driving pattern?
Have you had the amber or red DPF light come up on the dash?
Have you had any DTC’s relating to the EGR come up ?
Have you had and DTC’s relating to the DPF come up ?
With this data we will be better able to answer your question.
Post #1052146 19th Nov 2024 2:53am
MK
Otto and diesel engines are designed to operate at running temperature for various reasons. Short trips fall in the category of severe driving conditions. Engine oil takes a lot more time to reach normal temperature compared to coolant. Puma 110" SW
Post #1052169 19th Nov 2024 11:34am
lightning
Sorry l messed up with my acronyms. I meant DPF and not EGR
Post #1052171 19th Nov 2024 11:43am
lightning
Ianh wrote:
So,
l haven't got any data. l am looking at buying a Defender Puma 2.2 TDCi and am trying to find out how it might cope with this kind of use.
l've currently got a new (2022) Defender 3.0 diesel and that copes with it fine, done 17,000 miles over two years and had no issue at all.
But the new one has been designed around the DPF and it's known not to give issues.
Post #1052172 19th Nov 2024 11:46am
Chicken Drumstick
If you only do 2-3 miles in a day, maybe as two journeys hours apart, likely more of an issue.
But if you are running about doing many journeys, even short ones in a day, the vehicle will get up to temp, as it won't have fully cooled down. Also if you go for a longer run at least sometimes. I really can't see it being an issue.
The 12 plate I mentioned in the other thread might be lowish mileage, but all of them have been "farm" miles pretty much. So short journeys in the local area or over the fields.
Post #1052175 19th Nov 2024 12:01pm
Ianh
lightning wrote:
Ianh wrote:
So,
Ahh ok, the way your original post was worded lead me to believe you had a 2.2 Puma already.
Given the nature of your journeys, I.e predominantly very short start stop journeys , you will fill your DPF quickly and will significantly impede the possibility to reduce the build up in the DPF with passive and active regenerations. With that sort of cycle you will really need to take the vehicle on a 30min constant 60plus MPH journey at least once a week.
Post #1052183 19th Nov 2024 1:22pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
The thing with the DPF is that it gets clogged after a while and then the engine has strategies to clean it. I don't know about the 2.2 specifically but usually the engine will 'regenerate' the filter by increasing the exhaust gas temperature to allow the soot particles in the filter to burn. This process is a bit time consuming as, 1) you'd like to start the process when the engine is warm already, 2) the materials can sometime be sensitive to rapid temperature changes, 3) the soot burning itself takes some time.
The engine will attempt to perform this when the filter has a high backpressure, and in your case it will fail over and over again (as for many others as well as many commutes are too short). Eventually the check engine light will light up.
If occasionally you mix in some longer trips this should not be a problem. I have the 2.4 so not sure how you can notice this on a Defender but on my previous car (Volvo V40 D4, MY2016) you could notice that the engine was attempting this. As I parked there was a certain smell from the exhaust and also the cooling fans was running for a few minutes to cool down the engine compartment.
This problem applies to all diesel cars with DPF but different OEM's might have different strategies to deal with it. But a 2.2 with DPF should have the same strategy regardless what vehicle it is in.
edit: Smile I didn't mean to repeat what Ianh wrote but with more words. I was just too slow.
Post #1052185 19th Nov 2024 1:29pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I drove my puma in the way you describe. I went on a long drive which induced a regen of the DPF and at the end it dropped from 90% to 15%. After under a dozen shorter drivers, in town and not many miles, the DPF climbed to 65%.
Truth be told, even on a long motorway journey the DPF fills up quickly. I started a 3.5 motorway drive at 35% and after just over an hour it got to 85% and then a regen took place.
Hope this helps
P
Post #1052245 19th Nov 2024 9:54pm
lightning
Thank you for the information.
Maybe l would be better looking for a 2.4 Puma. There's plenty of those about and they're cheaper.
Post #1052272 20th Nov 2024 9:06am
DAZ110
Beware of the higher road tax on certain 2.4’s
Post #1052279 20th Nov 2024 9:37am
TexasRover
Diesels used to be the robust options, but they have come fragile. For the use you describe petrol would be better, which is going to be difficult to find obviously, unless you move away from Defenders.
There is the Td5 option (or 300tdi). Not sure how that fits in with your needs/expectations.
I confess that typically I drive my Td5 for too short a distance (shops and back etc). Had to the CT (MOT) and it failed on emissions ~3.5m-1 (whatever that is, but should be less than 3). Took it for a proper 60 mile hard run on the motorway and test came in at 0.17m-1. My 2015 Discovery 4 STDV6 tested at 0.10 m-1. Not that big a difference I thought?
Post #1052282 20th Nov 2024 10:35am
