![]() | Home > General & Technical (L663) > DRL failure. Some good news. |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1136 ![]() ![]() |
My car is 10 months out of warranty and I didn’t take out extended warranty.
Recently the left hand headlamp drl went out. New headlamp required. Also front parking sensors packed up. Took it to Williams JLR in Stretford who have repaired the car. Good news is Land Rover contributed 80% of the total invoice. Just posting in case others have same issue. It’s fairly common on early cars. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 369 ![]() ![]() |
Great news!!! and good for LR from time to time!! 👍🏼 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1494 ![]() ![]() ![]() |
Will the bad news be in another 3 years time when they won't make any contribution to the third set of lights?
Not sure. I did ask whats going to happen if the other side fails next week! Sounds like they are dealing with this and it’s early headlamps, so hopefully the problem will die away. 2021 Defender 110 X-Dynamic HSE D300 MHEV
oboe Member Since: 17 Jun 2024 Location: SDCA Posts: 3 ![]() ![]() |
added some gallery photos too
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Carpathian110 Member Since: 02 Nov 2024 Location: Ireland Posts: 25 ![]() ![]() |
Looks like an awkward job. I’m sure there are others who would appreciate a thread for this
JohnnyO Member Since: 28 Jul 2025 Location: Calgary Posts: 1 ![]() ![]() |
Oboe, how did you get the clear lens off the back housing? I've found other non-LR videos showing how to heat the entire headlight up in an oven to soften the butyl glue and then prying it open. I see powerfuluk have complete repair kits that include the lens and back/main body - I'm hoping to avoid this cost and only replace the DRL circuit board.
