Home > In Car Electronics > Interior light problem
silvermilnec
Hi guys hope your all well, not been on here with my own post but use the site for info, so had loads of help without anyone knowing so thank you!
I couldn’t find details of my problem so here goes.
I’ve done a few upgrades and seem to have caused a problem.
I’ve done the ultra gauge mod into the binnacle and fitted heated optimil wing mirrors arms with the led puddle lights.
All done and working but my problem is my courtesy light used to come on when remotely (Clifford 650 alarm module) unlocking. When I open any door they come on and when I lock they go out after about a minute. I’d just like them to come on when unlocking with the alarm fob.
Any clues??
Post #1051234 10th Nov 2024 2:02pm
Trev
Scotland 2008 Defender 110 Puma 2.4 USW Zermatt Silver
I have the same wing mirrors and they work fine, so it's probably an install issue.
I seem to remember that when I fitted them I had to wire them into the alarm ECU, which I expect controls the lights when you lock/unlock. I'm guessing you might not have plugged it back in properly or maybe nicked something.
The lights come on and off with the door switches making/breaking the earth connection for the lights, so probably don't need the ECU to be doing anything to work.
Post #1051525 12th Nov 2024 11:06pm
silvermilnec
Cheers Trev, I’ve wired as per Optimill instructions, I’ll take another look. Funny thing is they are coming on when the doors are opened.
Post #1051537 12th Nov 2024 11:53pm
Trev
That's why I think it's the connection to the ECU that's the problem. The doors have a physical switch to earth the connection and turn the lights on, the ECU is needed to do that job when the doors are all closed.
I'm assuming the puddle lights come on when unlocking and it should be the same wire that's doing the interior lights, so I think you should check that connection. I always use these when splicing stuff inside the truck:
https://www.wago.com/gb/electrical-interco...installers
Mainly because I'm never sure I'm going to get it right and also I don't fancy setting fire to my Landy with a soldering iron. Basically I'm incompetent. Very Happy
Post #1051538 13th Nov 2024 12:21am
silvermilnec
Thanks again, to be clear the puddle lights and the courtesy lights only come one when I open any door.
They stay on and go out at the same time, so when locking the car they all go out on the timer so about 30 seconds after locked or that could be after the doors are closed.
Post #1051565 13th Nov 2024 10:18am
Trev
They should also come on when you unlock the truck with the fob, so I think the problem is definitely where you spliced into the ECU. I think the wire colour you want differs between models (Puma V's others). I can take a picture of mine for you, but not until Saturday I'm afraid.
Edit: Mine's a 2.4 Puma.
Post #1051572 13th Nov 2024 11:16am
Trev
This is what mine looks like. I bought their wiring loom at the same time, so if you didn't these wire colours might not actually be relevant.
At the ECU I've spliced the purple wire with the purple on the loom and the purple and white on the ECU with the purple and white on the loom.
Hope this helps.
Post #1051939 16th Nov 2024 9:22pm
