Home > Puma (Tdci) > P0240
jack 16
Belgium 2007 Defender 90 Puma 2.4 PU Blenheim Silver
P0240
hello i have the code p0240 on my def td4 2.4cc 20007 ? thank you
Post #1051352 11th Nov 2024 7:45pm
jack 16
P0240
Post #1051357 11th Nov 2024 8:16pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Sorry, I have checked my workshop manual, and online, and that doesn't seem to be a valid code for a Puma engine.
Post #1051385 12th Nov 2024 5:26am
jack 16
P0240
merci je vais reverifier
Post #1051450 12th Nov 2024 6:28pm
GuJa
Germany 2008 Defender 90 Puma 2.4 SW Tonga Green
Hi, P0240 means "P0240 Turbocharger/Supercharger Boost Sensor "B" Circuit Range/Performance". Hope this will help you.
Post #1051477 12th Nov 2024 8:52pm
jbcollier
Yes, but that is for another engine in another platform (Range Rover). It's not a valid code for the 2.4 or 2.2 Puma engines.
Post #1051501 12th Nov 2024 9:44pm
andy63
The 0 after the P indicates its a generic or standardized obd code and not a manufacturer specific code..
Manufacturer specific will start P1
Post #1051548 13th Nov 2024 8:18am
jack 16
P0240
merci
Post #1051624 13th Nov 2024 7:18pm
jack 16
p0240
voila j'ai trouvé la panne , la geometrie variable du turbo etait bloquée .
j'ai démonté le turbo et tout nettoyé ,graisser l'axe remonté et le test est ok.
mon def roule tres tres bien.
Post #1053453 30th Nov 2024 1:34pm
Thumbs Up Lubricate the Turbo actuator pivots fairly often with light oil.
Just like the timing of greasing props etc, if not been done for a while you can disconnect it (the turbo actuator pivot circlip) to check the vanes are free and not sticking too.
I tend to do these things about each quarter, or every 3 months roughly.
If you leave it too long, that’s when things get gummed up, grease solidifies etc etc.
LR do I believe a Ceramic grease for it, there is a PN for it but I seem to remember it’s a ridiculous price such as £75 for about 5g tube, even then being grease, it will handle the temp but will get gummed up over time, which is why I use a 3 in 1 light oil dripper on those pivots, and you only want a few drops on it there as the Turbo gets very very hot so don’t spray lube all over the place there.
When the actuator gets sticky, you can then end up in limp mode out of the blue.
And that will only improve if you shut off the engine and restart, and providing it doesn’t stick again 5 minutes later.
It can throw up the Turbo under boost code or over boost too, and not be the vanes at all.
Keeping the MAP sensor clean and MAF are a good idea too, but they don’t need doing more often than just once a you cold do it every other year like servicing, but I wouldn’t leave it longer than that.
Brake cleaner aerosol or MAF cleaner spray is ideal, and the MAP manifold stud torque is 3NM.
It’s useful to keep an eye on even if you don’t have any issues currently, you never know. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1053455 30th Nov 2024 2:30pm
Ianh
Translated.
“here I found the fault, the variable geometry of the turbo was blocked.
I disassembled the turbo and cleaned everything, greased the reassembled shaft and the test is ok.
my def runs very very well.”
Post #1053456 30th Nov 2024 2:31pm
Google translate is useful. Laughing _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1053458 30th Nov 2024 2:33pm
jack 16
Thumbs Up Thumbs Up
Post #1053489 30th Nov 2024 7:30pm
