Home > Td5 > AC stopped working
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
AC stopped working
Any AC experts on here who may be able to assist??
My AC stopped working in the spring, had the system drained, tested and refilled (first time in 10 years and it was only slightly low). No leaks identified.
Worked fine all summer. Stopped working again in September. Nanocom can trigger the compressor and its not seized. Fan works fine as well via Nanocom and 12V directly. AC blower works as it should. Disassembled both switches and cleaned them then reassembled and still no joy.
Finally decided to have my LR indie garage specialist have at her. My mechanic suggested we try the receiver dried after the refill machine identified the system was contaminated. Changed receiver drier, refilled properly, still not working. Wiring diagrams do not match my VIN according to Topix and the electrical library does not have values to measure for input measurements on switches, trinary switch etc. Decided to change the Trinary switch, still not working. Temp sensor to AC module in the evap is working according to their tests. AC control module was switched out with a spare and its still not working. Simoly cannot get the compressor to trigger and start cooling Big Cry
Any ideas where to go from here?
Thanks for reading… 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1051452 12th Nov 2024 6:38pm
bankz5152
I would be shocked if you condenser is still functioning correctly. Id replace that, regas and go from there.
Post #1051463 12th Nov 2024 7:50pm
4RF RDS
Really?!? Hmmm, that’d be a new one on me! Never seen one fail being completely intact and in good shape.
Thanks 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1051473 12th Nov 2024 8:42pm
bankz5152
Mine was brand new LR one, new seals. It leaked out every 6 months, gas would only last the summer.
They may appear to be in good condition but often arnt
Post #1051475 12th Nov 2024 8:50pm
4RF RDS
No leaks now, but could it be blocked internally?? 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1051485 12th Nov 2024 9:04pm
What pressures are you getting in the HP and LP lines with the compressor running and with it not running?
Post #1051536 12th Nov 2024 11:46pm
4RF RDS
I don’t have those values. The compressor won’t engage… I’ll see if my guy has them recorded for not running and report back.
1967 MGB GT
Post #1051543 13th Nov 2024 3:43am
Ah, OK, I missed that bit in your original post. Embarassed
So compressor works from Nanocom but not autonomously. Suggests that one or more of the switches involved is haywire. Let me ponder about this for a bit to see if I can come up with any ideas.....
Curiously my TD5 Disco2 has been exhibiting odd A/C symptoms as well, but I am not sure how similar the two are. I have more or less understood how the Disco2 is supposed to work.
Post #1051554 13th Nov 2024 8:55am
TexasRover
Sounds like more of any electric issue. So its a 2000 and should therefor have the 'add on' AC module at your knees. The wiring diagram for that is easily attainable.
Unlike a really simple system there is an electronic thermostat through the controller and the engine ECU has some control over the Compressor and Fan too. Its a pretty simple system and you need to chase back the power supply check the relay functions and wire continuity. It could be the controller but most likely there is a relay or power supply fault.
Post #1051564 13th Nov 2024 10:11am
4RF RDS
So I am able to make The AC run by bridging the relay wires with the relay removed. The wiring works as does the relay but the switches do nothing when the relay is put back in place. The blower works fine and the fan works as does the compressor when I bridge the wires. I’ve traced the wiring in the switch loom to the blower and temperature control switch and all is good.
If I can make it work by bridging the relay wires I suspect that it is not getting a signal from the engine and or trinary switch🤷‍♂️. Anyway anyone have any other ideas where to check?
Thanks [/quote] 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1053118 27th Nov 2024 6:02pm
PoormansXS
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Are you still having trouble with this? I just kind of skimed over it at work but I have a cool air Logan manual somewhere that I think tells you how to connect the under dash unit bypassing the ECU control. Let me know, I installed the system in my 90 so got to know it quite well
Post #1057039 11th Jan 2025 3:31pm
4RF RDS
Indeed I am still unable to make it work as it should. Any further assistance would be welcomed. Thank you. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1057059 11th Jan 2025 5:48pm
PoormansXS
Firstly- I’m not an automotive electrician I’m a factory engineer so anyone feel free to jump in and help out if anything I’m saying doesn’t look right.
The fact that you’re able to trigger the compressor via nanocom obviously means everything from the ecu output is healthy so either
- ECU conditions for compressor to kick in aren’t being met
Or
-the compressor request signal from the underdash unit is not reaching the ECU
Firstly I would check voltage to connector c0658 pin 23 on the ecu with the air con switch in position 4 (max cold) and position zero. With the engine and blower running (purple wire with black line in middle on picture) if you see voltage go on/off then your dash unit is sending the run request to the ECU.
Feel free to PM me and when I’m free I can do some testing on mine if needed.
Post #1057088 11th Jan 2025 8:22pm
4RF RDS
Excellent thanks for the help. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1057092 11th Jan 2025 8:51pm
