Home > Td5 > Left wing top removal
Scottyboy
Germany 1999 Defender 110 Td5 SW Chawton White
1999 Td5 110 CSW
Is it possible to remove the left wing top without removing the entire outer wing? If so, how difficult is the job?
I have a badly dented wing top, but the rest of the wing is good. Not sure if it would be worth it to try to repair the panel or just replace it. I have new 3mm checker plate for the wing tops, but the dents are too long/wide/deep to install the checker plate.
Thanks in advance.
Post #1051136 9th Nov 2024 10:32am
TexasRover
Although there are three pieces (top front and side) only the side is removable. The top and front are rivited together, so yes removable but only with a bunch of effort. (There is the inner plate too actually)
The whole wing is fairly easy to remove and you can buy complete replacements.
If you don't mind the chequer rash surely you could hammer the top plate up a little before fitting your chequer plate?
Post #1051189 9th Nov 2024 8:42pm
Scottyboy
Thanks for your reply. I will give it a try.
Post #1051202 10th Nov 2024 5:57am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If you don’t like diamond plate wing tops, look for smooth aluminum plates. Much easier on your elbows and knees. Thumbs Up
Good luck
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1051246 10th Nov 2024 4:42pm
Scottyboy
That does look nice.
Post #1051263 10th Nov 2024 7:44pm
