![]() | Home > Puma (Tdci) > Trailer reverse light feed |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2256 ![]() ![]() ![]() |
if its a std 7pin 12N style the it does NOT support the Reverse........
https://www.westerntowing.co.uk/trailer-ca...g-diagram/ if its the later 13pin type then its pin 8 / Pink as for the std harness it travels from the 12N socket up the rear of the OSR wheel arch (behind the plastic liner cover normally) and plugs in near the top of the arch |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1280 ![]() ![]() ![]() |
I wouldn't think the 13 pin socket was ever standard on Defenders. The 2015/2016 wiring diagrams indicate only 7 pin socket was used.
If the OP is using a converter 12N 7 pole -> ISO 11446 13 pole only the original core functions of the 12N are passed through: https://en.wikipedia.org/wiki/ISO_standard...connectors Go to the USA and they can do the whole thing with 4 connectors, seems a bit simpler and in the end more reliable. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
There is the reverse feed to the tow bar loom though from memory. I’m sure that is where I picked up the supply for my extra reverse lights.
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 159 ![]() ![]() |
Thanks for that- mystery solved then.
(For completeness, the trailer was supplied by Ifor Williams with a thingy to convert the plug. I have no recollection whether they mentioned that the reversing light wouldn't work.) Cheers, Guy. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
No tow electrics were ever "standard". All accessory/dealer fit. 13 pin electrics accessory was available from new for Pumas (at the very least, maybe Td5) ![]() ![]() |
Martin is right.
There is 12N, which is the basics excluding reverse, which most have - sometimes with an additional 12S socket. Which does have the reverse features. So there is two sockets on the towing vehicle if 12N and 12S. Then there is 13 pin, which homogenises both sockets into one, plus adaptors you can use to swap between various options. So for example if you have 12N on the towing vehicle, and a 13pin trailer, you can get an adaptor but the reverse lights won’t work. But indicators etc etc will do. I expect you can get a 12n & 12s adaptor to 13 pin. Mine has 12N, ideally it would be better to have 13pin on the towing vehicle as it then has the accessible supply such as the reverse light power, but you can adapt back to 12n if you have a 7 pin 12n trailer plug. Hope that helps. I’ve often looked at going to fit the 13pin, but never got around to it. Is there much involved with fitting? _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2423 ![]() ![]() |
The genuine Land Rover defender 13pin socket and loom is part number LR005919, circa £170 inc vat.
Note , if you fit the 13 pin socket it is tested as part of the MOT ( the 7 pin 12n is not ) so you need to ensure it’s part of your pre MoT checks. |
That is really good info to know Ian, I wonder why that is?
Presumably it is because the 13pin is typically considered the most modern / recent fit option. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 22 ![]() ![]() ![]() |
There is a plug behind the RH rear wheelarch mud cover, into which the towing wiring loom plugs. Hard to believe I know but I think it sounds like there may have been a bit of water ingress behind the cover (held on I think with 2 screws, you'll need an 8mm socket). I'd take the cover off off and have a check of the state of the plug - not hard with the wheel off. It has connections to support 13 pins (whether they all do anything I don't know but the trailer reverse lights and the permanent 12v work)
