![]() | Home > Puma (Tdci) > Fuel rail temperature Puma 2.4 or 2.2 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
I think I found it. Nanocom readings are wrong. Puma 110" SW
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Did you update to the latest version 1.38 from sept 2024 ?
They corrected their faulty OBD readings since the DPF reset did not start (with their faulty oil temp read out) |
Yes, I have the latest version. Not the first issue I found on the Ncom. 2.4 users may find that the engine temperature displayed at the pump learn menu is totally out of range. I had to show BBS two cases of this issue to then believe me. It took about 2 weeks for them to fix it. I cannot remember the date, but it was not long ago. Puma 110" SW
