Home > Td5 > Play in steering
excossack
Play in steering
I have some play in the steering. Anyways, I got a mate to wiggle the steering wheel while I was underneath and with my hand on the ball joint for the drop arm it feels like there is some play, it feels like the ball joint Sad (new part in June). Well its either the ball joint or could it be play in the connecting rod that connects to the ball joint? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1050717 4th Nov 2024 2:47pm
Dinnu
Very unlikely. Ball joints are taper and they sit pretty snug as long as the nut is torqued to the correct specification. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1050721 4th Nov 2024 3:26pm
excossack
I didnt think it would be that end but had to ask. Looking more like a drop arm again Sad
How ever, I might just try giving the nut a tweak to make sure. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1050723 4th Nov 2024 3:39pm
jst
Fit a disco drop arm and TRE with new drag link. Far simpler design and easier onward maint as only a tre. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1050736 4th Nov 2024 5:25pm
excossack
Something like one of these from a Disco 2?
I have seen the disco drop arms on Glyn Lewis 1999 Defender TD5 110
Regards
John M0VAZ
Post #1050746 4th Nov 2024 8:14pm
landy andy
Post #1050759 4th Nov 2024 9:31pm
excossack
Thanks but sold. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1050781 5th Nov 2024 8:57am
Dinnu
Unless you already have and need sumo bars, a standard Disco drag link is enough (and you need the drop arm). Possibly easier to replace a tre, unless the thread is seized in the drag link, but I find that the standard Defender drop arm ball joint to be just as good. You just need the tool to push out the inner ball joint cup. Dont hammer on the drop arm. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1050784 5th Nov 2024 9:26am
excossack
I have no need TBH. I couldn't justify the price TBH.
I have a puller for the defender drop arm so I might just look to replace the arm with another one but not the same make as before (will check paper work) 1999 Defender TD5 110
Regards
John M0VAZ
Post #1050785 5th Nov 2024 9:42am
Dinnu
Did you replace the complete drop are or just the ball joint?
I was curious last night and saw some ball joint rebuild kits which were more expensive than complete drop arms including balljoint. So that could be either one is doing a huge margin on the ball joint rebuild kit, or the quality of the drop arm/ball joint is questionable. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1050789 5th Nov 2024 10:45am
excossack
I replaced the whole drop arm with ball joint already installed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1050790 5th Nov 2024 10:48am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
The LR workshop manual states that you shouldn't test the steering ball joints by rocking the steering wheel side to side, but you should try to push / pull on each individual joint. Does anyone know why that would be?
Would you be more likely to detect movement by focusing on individual joints or could the steering wheel option give a false indication?
Post #1050798 5th Nov 2024 1:08pm
jst
Rocking the steering moves the whole system so whilst it identifies you have play I guess they are suggesting it doesn't tell you where the play is which pushing/pulling individual joints does.
Personally I rock the steering. Mot guys jack a wheel and rock that back and fwd against hub.
Ref changing a drop arm or changing a ball joint again after a short period of time I would suggest something is wrong with the quality of parts.a ball joint should last over 100k miles with light off roading.
Personally I find winding out a TRE alot easier than changing a ball joint which on an off roader where joints pick up external damage and are usually pushing hard in rocks/mud with big tyres is a massive benefit. On a road going vehicle I see there is less of a need.
If looking at using discovery drag link just check how your going to mount the damper if your retaining it Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1050803 5th Nov 2024 2:04pm
excossack
Cheers all. I will take a closer look at the steering system/components when I have a spare day/weekend to do so.
Not the first time I have had steering components fail/wear prematurely. The last was the steering shaft to steering box that had play in a bush. Replaced with an old spare I found in the shed with zero play. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1050804 5th Nov 2024 2:44pm
Mo Murphy
Gwyn Lewis sells a bracket for the steering damper if you change to disco drop arm.
50 Shades of Pennine Grey
Post #1050807 5th Nov 2024 3:42pm
