![]() | Home > Td5 > TD5 remap |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
It should smoke a bit, nature of tuning diesels. Also depends what was changed and why. More fuel (at least to some extent) will help off boost performance, which might be desirable, but will generate boost. And using a stock turbo you will have limitations of the stock boost threshold. |
Ultimately it really comes down to what you want to achieve vs what you want to spend. I know there is talk a few posts back about 300hp, but the reality is, this is exceedingly rare and how reliable is up for debate, due to such a small sample size of people making this power. However, the motor industry does show how these changes have happened too. Just look at the new Defender, 240bhp standard with warranty and meeting emissions from a 2.0 litre diesel. Unheard of power levels years ago. With the Td5, the stock air intake might not be the best for max power, but it is good for general use and off roading. So you may want to weigh up overall priorities. Likewise, free flowing exhaust can be an important part of an entire tuning package. But can be costly and often loud, depending on how you spec/build it. A good intercooler upgrade and a rolling road remap by someone who knows what they are doing should in all likelihood make it drive very well. Going much beyond this and you may want to start to look at the cost of doing an engine conversion instead. A 300hp Td5 is likely more expensive than a 300hp M57 or Chevy LS conversion. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2360 ![]() ![]() ![]() |
M57, stage one 250bhp, standard turbo, 2.5" exhaust, no smoke. 😉 Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
Surely not, although many do. Smoke indicates that more fuel is being injected than can be fully burned with the available oxygen, and that extra fuel is not generating power, it is just being wasted and only partially burned. A good remap will be clean and avoid exceeding the maximum fuel load for the available oxygen. My BAS map doesn't smoke, and even the relatively unsophisticated "tuning box" I have on my Disco2 doesn't smoke. Just as with a steam railway locomotive, with a diesel engine all that smoke indicates is that fuel is being wasted. |
Yes the M57 can make good power and be fairly clean. A little haze, not completely smoke free. Suspect this one is running a similar setup to yours. |
tbh I don't really believe yours makes no smoke at all. Even 100% standard and brand new both the Td5 and M57 will make a bit of smoke under full load at wide open throttle. --- Edit to add: you might not easily be able to see the smoke from the drivers seat while concentrating on driving, but that doesn't mean there isn't any smoke. And it depends how something mapped and its intended use. Smoke may well be unburnt fuel, but that doesn't mean you aren't still making gains. Hence why any professional competition where diesels are used such as tractor pulling or diesel drag racing, they always smoke...... To a certain point, more smoke will still give you more fuel burnt and thus more power, you just have more wastage too. Obviously for road use you want to keep the smoke levels down, but it doesn't mean you get the most power with zero smoke. |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 ![]() ![]() |
Hi All.
New uprated Intercooler fitted, (Darkside). Bit of a strange one feedback wise. Initially, I could sense the truck felt smoother and seemed less smokey (a bit more poke and less smoke), which was what i was after. However, when the engine was fully warm, the response / power seemed to drop off. I'm not sure if it was increased turbo lag or something, or I need to check the hoses and clips again - maybe small leak. It felt like she didn't want to rev freely. Was wondering if the boost needs upping because of the new intercooler? Will check the basics first, but was unsure why things were better when cold, rather than warmed up? Unfortunately, I don't have a boost gauge or Nanocom, but I do have the Empire Just Map It device, don't know if it shows boost pressure anywhere, at least I couldn't immediately see it on the parameters? BTW, also have performance air filter fitted and i think that made a small positive difference on it's own (fitted and tested before intercooler). Thanks for any suggestions / wisdom. Cheers. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2216 ![]() ![]() ![]() |
Hey,
So with the just map it, you should be able to read boost pressure under one of the live parameters. Will probably read in bar, I havnt got my laptop with me so can't check this second. A boost leak would mean more smoke really. As you have the just map it you can read and clear fault codes so wind the boost up to 1.2bar or 18psi. |
Thanks Bankz.
I took it for another drive and everything seemed fine with improved 'driveability' and 'smoothness' I'd say (I haven't changed / adjusted anything since this morning)! I will clear the diagnostic info / errors and go for a spin and get clean info. Regarding the Just Map It, I still can't find Boost pressure, I can only find ambient air pressures and inlet manifold pressures, but I thought that was different to boost pressure? Possibly, boost pressure is the difference between ambient and intake manifold pressures? Cheers. |
mat430 Member Since: 22 Apr 2024 Location: cheshire Posts: 3 ![]() ![]() ![]() |
I just had my remapped stage 2 at Nomad at macclesfield, who are an Alive dealer my ecu was none flashable so had to be sent away.
The car is totally changed i can highly recommend Nomad https://www.nomad-uk.co.uk/ |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
when you drop in a larger intercooler, it's going to need more volume of air to fill it. so you might notice at around 1k to 1.2k rpm, there's some power loss.
the theory of tuning has not really changed, but the method of tuning has as people understand the ECU parameter relations to each other. a defender running far up north in colder climates vs one that run at the equator. you will see that what used to smoke while on the equator now doesn't smoke far up north due to the cold air. I've moved mine far up north so i know. in this context, air temperature and density. with colder air, you do get better performance as the law of physics says it's more dense. also when you move a defender higher up away from sea level, the air is less dense so you will need more air to achieve a similar performance. in this context, air temperature and pressure. injector conditions also make a difference, cos the finer the spray mist the more surface area the diesel particles has in contact with the air. it doesn't mean dumping in more fuel by opening the injectors longer will make the magic happen. the spray patten inside the cylinder makes a difference too. fuel temperature also makes a difference to this. hence you do have a fuel cooler. finally, you always need to consider the amount of air coming in and at what temperature to mix with the fuel. too much fuel (too little air) results in smoke but no poke. you want to make sure you are burning just slightly below optimal (less fuel injected) to cater for less than optimal situations. specific to the defender the road speed of the car will vary the response of the throttle pedal. in contra to some who believe that the defender doesn't use the road speed, it does. so being a drive by wire car, this helps smoothen out the driver demand and deliver a smoother reaction. there's enough information out there to write your own map and have good fun with it. The defender has migrated, leaving the owner behind. |
