Home > General & Technical (L663) > Cant clear codes with Gap G3
xexitenglishx
United States
I accidentally changed a setting for my headlights and now i have a few ecu faults that i cant clear when i select the clear all option. please see the attached pictures. Is there any specific way i can clear these codes besides the clear all option which doesnt work?
Post #1050172 29th Oct 2024 12:27pm
DrRob
You need a G4 IID for the new Defender I thought? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1050214 29th Oct 2024 6:09pm
xexitenglishx
United States
I didnt think so just to reset codes. I have the g4 on order. Everything i activated seems to be selectable with the g3.
Post #1050217 29th Oct 2024 6:23pm
lightning
The tool stores your original settings so just reset the vehicle back to default settings.
Once you change something it sometimes needs to be driven in order to properly activate. l tried to set the more accurate speedometer and it threw up a "4wd not available drive with caution" error.
l reset it but the error remained until l had driven a short distance and cycled the ignition and then it cleared.
Post #1050222 29th Oct 2024 7:43pm
