Home > Puma (Tdci) > Play in steering
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Play in steering
Hi guys,
I seem to have developed some play in the steering. Under the bonnet I can turn the steering column with my hand 5-10 degrees before it feels like it engages.
Is this likely an issue in the steering box and a new one required?
Post #1050027 28th Oct 2024 1:55pm
DSC-off
There are a few things to rule out before assuming it's the steering box.
Is the play in any of the lower steering column joints or splines?
Is the play after the steering box?
Ie, does the steering drop arm have play or any of the ball joints on the steering bars?
If it is in the steering box, can it be resolved with adjustment? A last resort after checking all other possibilities.
Post #1050029 28th Oct 2024 2:20pm
BrickBox
Start with the free basics and check your tyre pressures. 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1050032 28th Oct 2024 2:36pm
TamarBlue11
Doesn't seem to any play in the joints or splines. I can just about see the movement/play being transfered on the shaft where it enters the steering box.
Can't see the movement the other side of the box.
Where can you adjust?
Post #1050033 28th Oct 2024 2:37pm
Bluest
These types of boxes usually have some play in the straight ahead and is not necessarily a problem. I wouldn't be too concerned with 5 to 10 degrees as that really isn't very much. If it gets worse, then obviously that's cause for concern. If you move away from the straight ahead, does the play diminish as more lock is added? If you do decide to adjust the box, be careful as it can then become tight at full lock. 2007 110 TDCi Station Wagon XS
Post #1050035 28th Oct 2024 3:08pm
TamarBlue11
Its strange as the play has only become noticeable over past few hundred miles.
Yeah play seems to go away once your away from straight ahead and into the turn. It's just that initial movement/play it seems almost before it engages.
Maybe my test of turning the steering column manually is a red herring if that sounds normal.
Post #1050037 28th Oct 2024 3:27pm
DSC-off
Are the panhard rod bushes ok?
If they're worn the axle will float from side to side until the steering is loaded up in a turn.
Post #1050040 28th Oct 2024 3:35pm
TamarBlue11
I will double check thanks guys. Apart from a visual check is it a case of putting a bar in and trying to give it wiggle?
Post #1050041 28th Oct 2024 3:51pm
Dinnu
I am quite sure that this is incorrect. The design is such that there will always be play when the steering is off center. While driving, due to the caster angle, the wheels want to return to center, so the free play will not be felt anymore.
The best way to check for steering box play, again with the drop arm pointing straight ahead, disconnect the ball joint on the drop arm from the drag link, then see if you can move the drop arm side to side. You should not feel any free movement in that position. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1050042 28th Oct 2024 3:56pm
andy63
What I've noticed with mine is occasionally when its parked up there is a bit of what you might describe as play at the steering wheel.. but not always.. with engine running the steering is fine..
I had a look at the diag of the steering box and there is a fairly coarse scroll with a follower on what is called the sector shaft..I think sometimes the bit play in that area manifests it's self as a bit slack ot the steering wheel when you shut down..
Post #1050096 28th Oct 2024 9:12pm
revd
I had a JLR engineer adjust mine (I paid with beer) he set the wheel straight in relation to the steering box etc, was noticeably better after.
Post #1050105 28th Oct 2024 9:57pm
Dinnu
Just keep in mind this is a steering BOX not a steering RACK. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1050127 29th Oct 2024 6:44am
You'll always feel a small amount of lost movement with the engine stopped due to the small amount of movement needed to operate the hydraulic valves in the box. You don't notice this with the pump running since the hydraulic pressure causes the box internals to follow the wheel movement.
Post #1050146 29th Oct 2024 10:22am
revd
The play gets worse the more lock you apply, if the box is off centre this play will manifest itself in the straight ahead position- this was the problem I had until a Land Rover guru sorted it out. There is also an advantageous orientation of the column between steering wheel and box that improves matters even further- I hadn’t got the correct e-torx to hand when sorting the slack in the box so a job for another day
Post #1050159 29th Oct 2024 11:35am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Be advised that the e-torx bolts in the steering column are stretch bolts and should not be re-tighten.
My splined joint between upper and lower steering column was badly worn when I bought the car. The dealer and previous owner had probably tried to solve the problem by re-tightening the bolt but it didn't last. In the end both parts had to be replaced.
The symptoms was a lot of free movement and the car was all over the road when going straight, but as soon as I turned and put some torque on the joint you couldn't tell there was a problem.
To diagnose I was able to hold my fingers on the two parts while moving the steering wheel, I could then feel the movement between them.
Post #1050193 29th Oct 2024 2:17pm
