Home > Technical > FRONT BUMPER LIGHTS WIRING
iamdimitris
Cyprus 2013 Defender 110 Puma 2.2 XS CSW Fuji White
So I got this Defender, and it already had bumper lights, but they were acting up – sometimes they’d turn on, other times not. While troubleshooting, I found that if I disconnected one light, two others would work, but the fourth wouldn’t, and it kept going like that.
When I restored and repainted the front bumper, I figured it was a good time to upgrade to a new set of lights (these ones: link).
But now, these new lights won’t work at all. They didn’t come with any wiring diagram, so I’m kinda stuck. Any advice on how to get these working would be awesome!
 2013 110 XS SW
1971 Series 2A LWB
2007 DCPU 2.4 (SOLD)
2015 DCPU 2.2 (SOLD)
Post #1049836 26th Oct 2024 10:18am
landy andy
No link for the lights Thumbs Up
But I would start with a single light, and a fused supply direct to battery and test each light in turn, so you know each light works, and what is pos, and what is neg on lights.
Next step would be to check current wiring, and make sure it is fused. Then wire one light to what should be the supply, and see what you are getting. If no light then go backwards through the wires and see how and what has been done, and I would assume you’ll find a relay somewhere that will require testing.
Once you know what you’ve got, link the lights, and do the installation.
The alternative is just to rip out the old and start from fresh yourself
Post #1049839 26th Oct 2024 11:00am
Ianh
Those look like LED daytime running lights. As such each pair will have a DRL controller and it’s likely a fault with one of them or its wiring that’s the problem. Each controller is likely to be located behind the headlights , that’s where I put mine.
I suspect you need new controllers that are compatible with your new LED DRLs
Post #1049842 26th Oct 2024 11:15am
iamdimitris
sorry, when posting I wasn't actually sure if links could be posted. my bad!
your process seems very good and will try to troubleshoot like that Thumbs Up Thumbs Up Thumbs Up 2013 110 XS SW
1971 Series 2A LWB
Post #1049851 26th Oct 2024 1:03pm
Ianh
The DRL LED light SHOULD NOT be directly connected to the battery, it is fed by a controller that provides the correct current and voltage. You need to locate the controller for each pair of DRLs and test them.
Post #1049857 26th Oct 2024 1:45pm
iamdimitris
the old lights had two controllers (vinstar drl module), one for each pair.
these controllers are identical to the new ones that came, so first I attached them directly to the old ones and when they didn't work I made pass through the new controllers. still nothing
 2013 110 XS SW
1971 Series 2A LWB
Post #1049880 26th Oct 2024 7:54pm
