![]() | Home > Tdi > Elring Head Gasket - No Hole version |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
You’d be fine with the one you’ve bought on an old Tdi, I’d be worried if it was the other way round. It’s not going to make that much difference in the grand scheme of it. The MLS gasket is a much better gasket.
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 228 ![]() ![]() ![]() |
The MLS gasket is better. If you originally had a no-hole gasket and now have a 2-hole, I'd be measuring the piston protrusion to make sure it's allowable. The difference between gaskets is 0.2mm. Also measure the gasket to confirm, 2-hole should be 1.4mm thick LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
withabix Member Since: 24 Sep 2013 Location: Vancouver, BC Posts: 8 ![]() ![]() ![]() |
The gasket 565.860 SHOULD be a 4-hole MLS gasket according to Elring, but I've ordered the gasket twice now, only for it to be 2-hole both times.
I just want to fit a no hole (which is the same as 4 hole per LR bulletin in 1997). Click on Gallery for the photos. |
Might I suggest getting in touch with Turner Engineering the absolute best people to deal with in LR engines? Frida will probably have it on your doorstep by the time you’ve the phone down!
The answer is even on their website- that’s why they’re the best ![]()
https://www.turnerengineering.co.uk/produc...&_ss=r ![]() |
Elring couldn't tell me that, and told me that it has 4 holes...🤷♂️
Suggests that Elring and Reinz might be exactly the same gasket in different packaging though... I doubt Turner provide quite as fast a service to....VANCOUVER...lol |
Oh they would! They’re a great company, incredibly knowledgeable, friendly and efficient!
