Home > Puma (Tdci) > VDO DTCO 1381 Tachograph
DaftOldGit
My motor had this tacho fitted when i bought it. I have no need of it, but when I unplug it the speedo and odometer stop working.
Does anyone have experience of these units? Is it just wired in series with the speedo somehow, and i can just short a couple of wires to restore operation, or is there more to it than that?
Post #488053 3rd Jan 2016 9:31am
Is it not possible to follow the loom back ?
Post #488055 3rd Jan 2016 9:52am
dorsetsmith
Re: VDO DTCO 1381 Tachograph
https://www.defender2.net/gallery/albums/u...rchive.pdf
Post #488063 3rd Jan 2016 10:10am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Those instructions are the old way of installing a digital tachograph, the short speedo cable didn't prove reliable. If it's an early puma it will be like this. If it's newer follow the loom back there should be a yellow box which is a M1N1 adaptor this will have a +30 and +15 power supplies also the speedo signal will feed into this, you will need to join the speed signal wires back together.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #488076 3rd Jan 2016 11:06am
DaftOldGit
Thanks for your replies.
Its a 2007 Puma, but i dont know when the tacho was fitted.
I'll have a look later and see which way it's been done.
I'm guessing that if its the older style then i just need to fit a new speed sensor and reconnect the original cable, then just unplug the tacho and leave the plugs as they are?
Post #488084 3rd Jan 2016 11:21am
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Hi DaftOldGit
Just found this thread. I have the same tacho unit and I was wondering if you might still have it kicking around as I’m after the cable?
Thanks Wil
Post #1049632 24th Oct 2024 11:45am
DaftOldGit
That was eight years ago!
I don’t even have the motor any more.
Post #1049734 25th Oct 2024 11:10am
Post #1049739 25th Oct 2024 11:36am
