Home > Faults & Fixes (L663) > Advice Needed:Repairing Dent in MY24 Wheel Arch
DC-Defender
United States
The garbage man dented MY24 rear passenger wheel arch, and their insurance is covering the repair. I spoke to a paintless dent tech, but I disagree with their approach. They suggested accessing the dent through the fuel pocket door but flap area, but after looking at the Defender workshop manual and my own inspection, I think that going through the fuel pocket is the same as going through the wheelhouse liner as both offer the same amount of access. There’s also a plastic piece behind the dent that blocks direct access to it. I think using a puller and glue is the better option.
Has anyone dealt with this before?
Thank you in advance for the help!
Post #1049443 22nd Oct 2024 3:07pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
I think that a dent repair specialist would be your best port of call. That looks as if it will push out without damaging the paint?
Jim
Post #1049457 22nd Oct 2024 4:36pm
WRFrance
Germany 2012 Defender 90 Puma 2.2 PU Keswick Green
Hi,
I would say a puller won’t work as well as the dent is too sharp and cannot be pulled out all the way without pulling/deforming the surrounding material outward too far.
This needs to be massaged out from behind with a block held against from the outside.
I think this can we done without the need to paint from the outside. Make sure they don’t damage the paint on the inside of the wheel arch to avoid corrosion at a later point in time.
Respect to your garbage guys for their honesty!
Post #1049465 22nd Oct 2024 6:17pm
lightning
Best to spray wax on the back of the panel after the repair just in case. Get a can of aerosol wax rustproofer and give it to the dent removal person.
Post #1049472 22nd Oct 2024 7:47pm
Ianh
If you are going to spray wax, use bilt hamber dynax UB
Post #1049484 22nd Oct 2024 9:23pm
revd
Funny how classic Defenders are similarly pockmarked and mostly left un-repaired
Post #1049489 22nd Oct 2024 10:04pm
Grouse
PDR will get rid of that no problem - I’ve had far far worse successfully removed than that. It needs massaging out from behind - more than likely glue will distort that and you will end up spraying it - which can be detected as spraying changes panel reflections and also you can see excessive paint depth
Post #1049493 22nd Oct 2024 10:30pm
ruben
Spain
I’ve see a total write-off for less!!🫢 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1049494 22nd Oct 2024 10:31pm
LR Nuts
It may be cheaper to replace all 6 plastic wheel arch trims, for the ones that fit further up the outer arch.
(Black on Black isn't the best photo)
Post #1049516 23rd Oct 2024 10:23am
ruben
Spain
That seems like a great idea!!
I did one similar thing!
this
motivated this!
These are the drawbacks of having elephant ears!! I suppose!! 😉 Defender 110 SE I6 D250 23MY
Post #1049518 23rd Oct 2024 10:59am
F-Typical
Re: Advice Needed:Repairing Dent in MY24 Wheel Arch
Unless you're either a PDR tech or work in a bodyshop that uses PDR techniques, probably best to just take before and after pictures to confirm you're happy with the result?
Post #1049955 27th Oct 2024 6:47pm
