![]() | Home > My Defender > Baltic blue 110usw |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Great maintenance your doing on the 110
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3630 ![]() ![]() ![]() |
One little tiny piece can cause havoc
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 622 ![]() ![]() |
All back in and running. Starter motor refused to seat properly and took me two hours of fiddling to get in. Just got to go steady and small journeys to begin with.
The ecu has called for an oil service on first start up. Little does it know the oil is cleaner than it’s ever been. I replaced the oil pump while it was in bits as it was part of the kit bought from lymm engine components (top service from them). |
Did you go for the gear type oil pump? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
No. The 2.2 needs a feed blocking to fit a 2.4 pump. There is a garage near to me who advertises this swap and he has been very freely giving with time and information on putting geared pumps into a 2.2. He has done it hundreds of times so fairly sure he’s has it right. He showed me all sorts of data on oil pressure he has gleaned when putting different oils into 2.2 and 2.4 converted pumps. Interesting but not at the same time.
The pump was part of a generic rebuild kit so went in. I will probably swap it for a geared one at a later date if this build lives long enough |
Busy summer hols again. Many miles covered.
Dash had to come out again to put a new gear on the new wiper motor. Don’t know why but it just ate the teeth. Overheated on a long drive due to low coolant. Could not find the leak despite having pressure testing gear then the radiator showed its hand and split properly so a new rad and stat went in. Still carrying water as a backup. Thinking about removing the now defunct egr cooler and cutting that leak potential out of the system |
The coolant leak finally showed. Head gasket was leaking so I fitted a new one and full timing kit while the head was off and therefore the timing cover. Done at 149000 It’s so much smoother now it’s back together. This probably occurred due to the big intercooler, remap, de restriction of inlet, exhaust and uprated turbo cartridge.
Cars are making demands of me lately. New def 90 needs a service, 79 vw t2 is mid brake overhaul, 68 vw beetle needs the same due to lack of use and slk Merc will get a gearbox oil change this week. I love it really. ![]() Click image to enlarge ![]() Click image to enlarge |
I recently noticed I had a slightly metallic sound like a ringing coming from the turbo. On inspection I found the shaft moving more than it should. I found a used turbo on eBay claiming it was one of three the seller had with less than 5k miles on it. For £200 it was worth a punt. It arrived as described clean tight and fresh. Fitted in about two hours and now running better than I’ve ever remembered it. The seller appears to break odd vehicles from the mod or aviation so the 5k claim is feasible.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2318 ![]() ![]() ![]() |
Good result 👍
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1089 ![]() ![]() ![]() |
Just read through this thread, hats off to you not throwing in the towel. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
Oh it gets better. It’s had another head gasket between posts. Buy cheap buy twice and double the work
I’ve had a wheel carrier fitted a couple of months now but the wheel was backwards due to clearance issues. Wet weather meant I had some time in the garage so knocked these up to extend the carrier for significantly less than being sold for online.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Love reading your posts.. not that I wish you more work, but may also be boring if everything is fine. For my 90 that still restoring (I need to do continue on that), I decided to go for Dot 5 brake fluid. It is expensive stuff, but hoping it keeps the system corrosion free. The brakes have not been bled yet, but the clutch is, and there is no tell tell signs of any corrosion yet (its high humidity over here). There is the concern of water pooling inside the system, which can then turn into vapor, but I do not think I will be going anywhere fast to get the calipers that hot in that thing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks Dinnu. I do try to keep a record of most work done on here but some does get missed. I do the same with the old vws on other forums. Lija Malta? Pretty place. My daughter sang there last year on a tour with school.
Jobs for next few days are good summer clean. New mirror arms and check swivel preload as I am getting a bit of a death wobble starting. |
