Home > General & Technical (L663) > Engine choice in a 90 which one would you choose (Pre loved)
Stacey007
Hello
Potentially looking at a Defender 90 to add to our mini fleet of cars.
It will be a pre loved one, but engine choice is all over the place.
From what I have read, the 3.0 seems the one to choose over the 2.0 but then there are 250, 300, 350, 400 (some petrol ones) and of course the V8
It will not be the v8... so what would you chose if buying one? if you had had a few engine which one would you choose. Mpg not a great concern and to be fair the 400 model seems quite nippy which would be fun.
I also like the first edition models as they seem to come with a lot of kit as standard.
Any thoughts...
Post #1048716 15th Oct 2024 8:22am
A1C6
Australia
The P400 is a really great engine in the 90, and definitely gives the car some 'oomph'. However, you will not be able to get the 18 inch steelies with that due to break size. The Diesel engines (D200, 250 and 300) obviously have varying levels of power, but great low-down torque (at least in the D300, don't know about the other ones) and really freaking long range. A D300 110 can do over 1100 km on a single tank on the highway.
Post #1048718 15th Oct 2024 8:26am
J77
Iโ€™ve had both D200 and D250 3.0, both are decent no complaints with pulling power of the D200. D250 though is more than enough for most tasks. 24MY 90 D250 HSE, Tasman Blue
Post #1048736 15th Oct 2024 12:37pm
CincyRovers1
United States
Depends if you are getting a gas or diesel. The 2.0 and 3.0 gas engines are both excellent and have proved to be quite reliable. We don't get the diesels here in the US, but the 2.0 diesel that was used for the first model year is prone to turbocharger issues and oil dilution problems. the 3.0 diesel doesn't have these problems. ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ‘ ๐๐จ๐ซ๐ฌ๐œ๐ก๐ž ๐Œ๐š๐œ๐š๐ง ๐’ (Dolomite Silver over Black/Bordeaux Red)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ• ๐ƒ๐ข๐ฌ๐œ๐จ๐ฏ๐ž๐ซ๐ฒ ๐‡๐’๐„ ๐‹๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐’๐ข๐Ÿ” (Aintree Green over Vintage Tan/Ebony) - Gone
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐‹๐‘๐Ÿ’ ๐‡๐’๐„ ๐Ÿ“.๐ŸŽ (Ipanema Sand over Almond/Arabica) - Gone
Post #1048737 15th Oct 2024 12:54pm
Moo
Ukraine
You need a minimum of 6 cylinders.
I havd a D250 110 and it's pretty impressive. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1048749 15th Oct 2024 2:41pm
lightning
D250 is all you will ever need.
D300 is a bit more power if you see one but probably not worth paying a premium for.
Post #1048751 15th Oct 2024 2:51pm
H1Tad
United States
The P400 is plenty peppy in our 110. Not the fastest but plenty of power to get around town. I imagine in a 90 it would be quite well. I will say that the 110 with the roof rack seems to struggle to get to 80mph. On most modern vehicles 80 is a stable cruising speed but on our 110 it seems like it just needs to be pushed to get there.
If mileage is also a concern, the P400 might not be the best choice. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package
2003 Hummer H1 P400 Firehouse Red
2008 Toyota FJ Cruiser
Post #1048759 15th Oct 2024 4:12pm
Crazymind
D300 seems the right engine. Itโ€™s good for everything does excel in nothing. This makes it for a superb workhorse of which youโ€™ll Never get tired of. 28 to 30mpg are achievable without any effort.
If petrol, I would go V8. Unless you do millions of miles per Year the consumption is not much worse than the other petrol options.
Post #1048793 15th Oct 2024 8:05pm
Retroanaconda
D200, D250 and D300 are all basically the same engine with different tunes. Any of them will be perfect. My 110 is a D200 and it has more power and torque then I can reasonably use.
Post #1048798 15th Oct 2024 8:33pm
Crazymind
True that! Not much difference in terms of torque between 200/250/300 and 350!
Itโ€™s the medium punch that makes the difference. 300/350 they pull to the red line without losing any power. And they all burn the same amount of fuel. D200 and 250 have more torque at lower rpm, 1200 compared to 1500 of d300 and d350. Other than that if second Hand I d go for 250/300. Power is never enoughโ€ฆ
Post #1048799 15th Oct 2024 8:39pm
CincyRovers1
United States
You can have the engine reconfigured to higher output levels using JLR's in-house Pathfinder software. So a D200 can be coded to a D350 just by changing the CCF files in the ECU. Since it is a factory tune, it will have no affect on the warranty. It can also easily be reconfigured to the original stock tune if you decide you don't like it. Companies like JLR Active can help you out, even though they're based here in the US. ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
Post #1048801 15th Oct 2024 8:51pm
Crazymind
I am not sure but I think I have read up to D300 injectors are the same. D350 has got different injectors?
Post #1048802 15th Oct 2024 8:59pm
Stacey007
All interesting points,
The V8 is out (although I'm trying to justify it) its too pricey yet as this is just 'another' car to add to the fleet for running around. MPG not an issue but depreciation on that would I think still be huge.
Interesting that the D200, 250, 300, 350 have the 'same' engine and as long as the 3.0 can be tuned.
That gives me more options looking at the spec I would like rather than engine and spec.
Post #1048825 16th Oct 2024 7:50am
Silb
Germany
I read somewhere that D200 has an aux cooler "missing" compared to D250 and D300. Worth keeping in mind (or checking) if you plan to increase the power output.
Post #1048826 16th Oct 2024 7:58am
A1C6
Australia
A couple of weeks ago I added a good table to the Defender Wikipedia page that could help you visualise this: https://en.wikipedia.org/wiki/Land_Rover_D...ailability
Post #1048840 16th Oct 2024 10:28am
